Tap Position
GAS
PostPosted: 06:33 - 06 Nov 2008    Post subject: Tap Position Reply with quote
Hi there can anyone help with regards to the Petrol tap position for my GS500e i just cant figure out ON, OFF, and RES positions it seems no matter what position i put it in it works fine
hmmmnz
PostPosted: 06:51 - 06 Nov 2008    Post subject: Reply with quote
there is no off position its on reserve or prime
the humans are dead
I kick arse for the lord
yen_powell
PostPosted: 13:47 - 06 Nov 2008    Post subject: Reply with quote
Put it on 'on' setting. When you run out of fuel (I wouldn't make a habit of it) you turn the tap to 'res'.
With the tap set to 'on' the fuel should only flow when the engine's running, so it's off when the engine is, that's the one for when you need to take the tank off.
Prime is just like having a permanently open tap, no suck required from the engine. Use this if you want to drain fuel out of the tank into a container for something (stove, mate, arson) or if the bike has stood for a long long time and you want to let fuel into the carb before starting.
XT1200Z and a DR350 in bits
GAS
PostPosted: 21:15 - 06 Nov 2008    Post subject: Reply with quote
Thank you for the replys thats been more than helpful
djr
PostPosted: 17:29 - 08 Nov 2008    Post subject: Reply with quote
There's no harm in running it to the bottom of on and i don't think there is to the bottom of reserve, running to the bottom of prime would pull through all the shit from the bottom of the tank which wouldnm't be a good idea (on and reserve work from an inch or two up from the bottom of the tank so it'll still be petrol for all of it.
PostPosted: 17:50 - 08 Nov 2008    Post subject: Reply with quote
Prime and reserve pull fuel from the same inlet (just that prime needs no engine vacuum to let fuel pass). Using either position because the fuel has run low increases the risk of getting dirt in the carbs. The more fuel in the tank, the less-likely it is that any dirt resting in the bottom will get agitated.
djr
PostPosted: 17:53 - 08 Nov 2008    Post subject: Reply with quote
Fair enoughs Thumbs Up.
yen_powell
PostPosted: 11:48 - 09 Nov 2008    Post subject: Reply with quote
The only reason I say not to make a habit of running onto reserve is the chance you'll be midway through overtaking a lorry when the bike starts to cough and splutter. Then you'll have to deal with that AND start faffing with the fuel tap at the same time......
djr
PostPosted: 11:56 - 09 Nov 2008    Post subject: Reply with quote
Fair enoughs but if you reset your tripmeter thingy when you fill up you'll have a good idea when it's going to happen so you shouldn't have those sorta problems.
The last post was made 17 years, 243 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.82 - MySQL Queries: 13 - Page Size: 62.66 Kb
