| lutmfurl |
 lutmfurl Derestricted Danger
| MarkJ |
 MarkJ World Chat Champion
 Posted: 23:20 - 06 Nov 2008 Post subject: |
You can get normal filament bulbs filled with Xenon gas which emit a brighter, whiter light than halogen. I've got a pair of Philips X-treme powers on my car and they do make a difference, these are the types of bulbs that have 50%+, 70%+, 80%+ stamped on the box.
You could also get HID bulbs which contain a capsule of Xenon gas that is ignited by an arc of ~23,000 volts which give a much brighter output, but require you to hide a ballast box somewhere on the bike which is usually the size of a fag packet. Also dubious whether these are fully legal on the roads (although I have a set on my Hornet and they're great ) |
| The Tot |
 The Tot World Chat Champion
 Posted: 23:21 - 06 Nov 2008 Post subject: |
Philips Xtreme Vision
Osram Night breakers
Both are very good incandescent bulbs and are much brighter than standard if you want illumination.
Nothing beats HID conversion kits altough you have to realise that they are NOT road legal. I've got HID's on my bike purely because I really DON'T like travelling through the twisties of the midlands coming home from london in the dark! HID's were substantially better than the Philips Xtreme vision, but you have to make sure that your beam is adjusted accordingly because they do project for miles.. you don't want to glare oncoming road users. But regulations say that HID's are illegal, but what's stopping us! ____________________ The Tot 2019 Z1000SX - 2007 R1
Never argue with autism |
| lutmfurl |
| The Tot |
| lutmfurl |
| The Tot |
 Posted: 23:53 - 06 Nov 2008 Post subject: |
Hmm. Firstly, check your manual which would state which type of headlight connection you have. I wouldn't like to make any assumptions but i would think that it's a H7 connection based on what you described with two bulbs used independently for high beam and low beam respectively. In which case, my suggestion is to only buy ONE box. Use that for the low beam, since it's the beam that's mostly on all the time.
So first thing's first
Check the connection that you have, it'll be H4, H7, H something or another, but DO check
Only BUY one HID unit for converting the low beam. There really isn't much point using a HID high beam. Fair enough it projects for miles, but the point is that most of the time you'll be using the low beam, so save your money and only get one. If you want to buy one HID for low and one HID for high, by all means you can do that, but finding the extra space for 2 ballast units will be a bit of a pain.
If you want to save the hassle, get the vision extremes  ____________________ The Tot 2019 Z1000SX - 2007 R1
| MarkJ |
| MarkJ |
 Posted: 23:57 - 06 Nov 2008 Post subject: |
Also, you can now get slim ballasts (which I have), they're pretty much the same length and width of the normal ones but half as deep. I managed to get two of these sat underneath my Hornet tank which has bugger all room under there  |
| lutmfurl |
| lutmfurl |
| MarkJ |
 Posted: 11:34 - 07 Nov 2008 Post subject: |
That ebay ad looks a little misleading - I'm not sure if he's selling just low beam or high and low beam.
The best thing to do is look in your Bandit's owners manual and let us know what bulb sizes it uses. Either that or pop the existing ones out of the headlight and have a look and see if it tells you what sizes they are on them.
Actually I've just looked further down at the bottom of that ebay ad - seems that you're paying £64 for one bulb kit which is quite a lot. You normally pay this for two bulbs. If you can find out what bulb sizes you need we'll be able to find a kit for you  |
| lutmfurl |
| Im-a-Ridah |
 Im-a-Ridah World Chat Champion
The last post was made 17 years, 243 days ago. Instead of replying here, would creating a new thread be more useful? |
