Split Link Chain installation - help?
Thom
PostPosted: 13:03 - 09 Nov 2008    Post subject: Split Link Chain installation - help? Reply with quote
Okay well, i've got a chain which came in 4 parts.
It's just got to get me to and through an MOT and then im getting a proper chain for it anyway.
So, how do i install a split link chain?
I have:
the chain itself
A half link (Link plate with two pins installed)
A link plate (Making up a whole link with the above piece)
2x clips (Of which one is thicker than the other)
And suggestions on how i install the link?
Also which direction should the open end of the clips be facing when rotating? into the direction of travel or away from?
Ariel Badger
PostPosted: 13:11 - 09 Nov 2008    Post subject: Reply with quote
The open ends point away from the direction of rotation ( at the top of the run they point to the rear wheel.
As for the other bits, use what you need for the shortest run.
Thom
PostPosted: 13:14 - 09 Nov 2008    Post subject: Reply with quote
cheers i'll have a go and see if i can fit it now Smile
yen_powell
PostPosted: 14:15 - 09 Nov 2008    Post subject: Reply with quote
You, may fire the fishplate across the garage a few times when you try to put it on initially, so be ready to see where it lands. Wink
XT1200Z and a DR350 in bits
Thom
PostPosted: 15:20 - 09 Nov 2008    Post subject: Reply with quote
Embarassed
Im buying a rivet link.
The last post was made 17 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.4 - MySQL Queries: 13 - Page Size: 44.96 Kb
