project mini buffalo... now with a better sounding vid
hmmmnz
PostPosted: 05:54 - 09 Nov 2008    Post subject: project mini buffalo... now with a better sounding vid Reply with quote
may i present.... dun dun dun
https://i58.photobucket.com/albums/g257/hmmmnz/79673809_full.jpg
mini buffalo
and just to how you how small this wee smokey beast is
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF1840Small.jpg
(excuse the moustache, its MOvember and all my work mates are growing mo's)
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF1841Small.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF1842Small.jpg
she's a 1975 60cc 2 stroke, with 1323 miles on the clock,
she has been sitting under a house since 1977,
and needs some work, she has frozen solid,
i was hoping it was a cold seize on the top end, but unfortuanatly its the bottom end Sad
i have stripped the engine down to the crank cases,
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF1856Small.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF1857Small.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF1858Small.jpg
but will have to drop the bottom end off, for the bike shop to split the cases for me... (i just dont have the tools to do it myself)
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF1851Small.jpg
well thats the progress so far,
im not sure what the bike is, the prevous owner seemed to think it was based on a old step through yamaha engine (apparntly the Taiwanese bought the tooling from yamaha, and started building there own bikes)
if you can think of any engine that is similar then let me know..
the carb is inside the right hand side cover..
very weird,
it also looks like you have to premix yourself,
fuck knows the mixture
the humans are dead
I kick arse for the lord
SoND
PostPosted: 08:17 - 09 Nov 2008    Post subject: Reply with quote
Looks like a class little project. Have fun.
yandy_yay
PostPosted: 08:25 - 09 Nov 2008    Post subject: Reply with quote
you got yourself a nice ' little ' project there, look forward to reading progreess reports.
its gonna be a mean green riding machine when its done Thumbs Up
past bikes: (20 years ago) cg-125 (wriiten off), C-50 (thrashed n' finnaly scrapped), CZ-125 (nicked - never recovered, insurance payout was more than i paid for it !!!)
Current bikes: GN 125(now sold), Divvy 600s.
PostPosted: 19:25 - 09 Nov 2008    Post subject: Re: project mini buffalo... (monkey bike extravaganza) Reply with quote
very weird,
It probably has a discvalve rather than reed valves, that is why the carb is underneath the crankcase.
I used a 32:1 mixture in my Raleigh Runabout. With modern day oils 32:1 should be fine, back in the days it was first made though it would have probably been run on something closer to 20:1.
hmmmnz
PostPosted: 19:56 - 09 Nov 2008    Post subject: Reply with quote
yeah it is a rotary disc valve system.
ive never come across that before, i ve always only dealt with reed valve smokeys. Mr. Green
the humans are dead
hmmmnz
PostPosted: 10:18 - 10 Nov 2008    Post subject: Reply with quote
ok progress today is that i managed to split the cases...
very easily infact, another first time for me was that there was a gasket between the crankcases,
that made the job very easy indeed,
here is the evillness that is my bottom end Crying or Very sad
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF1859Small.jpg
so crank cases split i have another problem, there is a little pin that is on the right hand of the crank that is there to spin the gear that spins the disc valve, which means i can't get the crank past the damn bearing...
am i right in thinking that the bearing should move out wards and not into the bottom end??
it has a circlip in place which makes me think that
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF1854Small.jpg
well thats it for today
the humans are dead
PostPosted: 10:33 - 10 Nov 2008    Post subject: Re: project mini buffalo... (monkey bike extravaganza) Reply with quote
The ignition cover to me reminded me of a Kawasaki one (some of the old air cooled singles, like the KH100). That is it disk valve makes me also think Kawasaki. A guess would be an early KX60 engine. The fins on the head look similar to this mid 1980s one.
https://www.sharptune.com.au/shop/shop_image/product/05ed861ee8cc5e2d35353c95fb2494bb.jpg
hmmmnz
PostPosted: 11:20 - 10 Nov 2008    Post subject: Reply with quote
yeah i was thinking kawasaki as well,
i am using a ga1 manual a 90cc bike from the early 70's
that seems kinda similar
https://www.taylorcompton.com/sitebuilder/images/kawasaki90-452x298.jpg
except the ga1 uses a autolube/oil pump, where the buffalo must run premix,
also the air filter system is different,
apart from that for all intensive purposes it seems very similar.
any clue on how i would remove the dowl pin from the crank??
https://www.bikechatforums.com/download.php?id=61638
the humans are dead
PostPosted: 11:33 - 10 Nov 2008    Post subject: Reply with quote
I would expect the bearing to stay on the crank when you remove it from the cases. Once out you might find you have clearance to get at the pin.
hmmmnz
PostPosted: 05:46 - 11 Nov 2008    Post subject: Reply with quote
well i managed to get that pesky pin free... very easily infact,
good old side cutters did the trick no bother,
bearing stayed in the case and the crank slid through,
hammered the bearing free,
and bobs ya uncle,
and here is the culpret... 32years with out being started and this is what you get
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF1870Small.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF1871Small.jpg
i did some measuring and found that the bore is 42mm and the stroke is 43,
so that makes this bad boy a staggering 59.57cc wooo hoo.
can you feel it???
the humans are dead
hmmmnz
PostPosted: 18:37 - 11 Nov 2008    Post subject: Reply with quote
well i finally found out what the bike is based on... well the engine any way.
a bridgestone chibi, as in the guys who make tyres,
up until 1975 they also made bikes,
and some quite cool ones at that.
heres the chibihttps://www.bikerenews.com/Stories/Article_20080806_001/MVC-044S.JPG
the humans are dead
Charlie
PostPosted: 22:22 - 11 Nov 2008    Post subject: Reply with quote
Damn that bike looks cool (the chibi).
Looks like a good project you have got, keep it up. Thumbs Up
hmmmnz
PostPosted: 07:24 - 01 Jan 2009    Post subject: Reply with quote
well finally she is alive!!!!
woohoo after 32 years of never being started she was kicked into life
on the second kick Very Happy
i had to use a pair of rings from a husky 45 chain saw which worked a treat Very Happy
im very stoked
ill post a video soon... once i figure out how Very Happy
the humans are dead
PostPosted: 15:13 - 01 Jan 2009    Post subject: Reply with quote
Good stuff Thumbs Up
hmmmnz
PostPosted: 08:21 - 02 Jan 2009    Post subject: Reply with quote
right heres a video
https://www.youtube.com/watch?v=mRnOzzOgNUQ
sorry about the crap sound, i didnt realise normal cameras picked up the wind so much
the humans are dead
Whosthedaddy
PostPosted: 11:16 - 02 Jan 2009    Post subject: Reply with quote
Put some shoes on you damn hippy!
Would have been nice to hear the wee beasty roar as looks cool as in the green scheme.
hmmmnz
PostPosted: 11:22 - 02 Jan 2009    Post subject: Reply with quote
lol, its nz, we dont wear shoes... no snakes or any thing poisonous here Very Happy shame can't be said for where your going Very Happy hehe
ill do another vid tomorrow morning Very Happy
the humans are dead
Whosthedaddy
PostPosted: 11:24 - 02 Jan 2009    Post subject: Reply with quote
Yeah don't remind me.
You ridden it properly yet?
hmmmnz
PostPosted: 12:01 - 02 Jan 2009    Post subject: Reply with quote
i rode it down the road in bare feet and no helmet and then proceeded to get pulled over by the police
lol, he let me off of course,
but bloody typical, never see cops at all, and then the one time you decide to be a bit sneaky, there they bloody are,
the wee bike seems to run quite hot, (compared to my other air cooled 2 stroke) so ill pull the head in the morning and inspect the bore and make sure every thing is getting lubed properly,
may be im running a bit lean, so ill pull the carb again and see if there is some gunk in there,
its strange to ride, one of the bars is bent, which is a shite, ill never find them here in nz
other than that she seems to go through all 4 gears ok
the humans are dead
hmmmnz
PostPosted: 03:00 - 03 Jan 2009    Post subject: Reply with quote
heres a better video... well better sound any way
https://www.youtube.com/watch?v=8qKgW1xoYxw
the humans are dead
PostPosted: 14:53 - 03 Jan 2009    Post subject: Reply with quote
Sounds good.
You could always get some handlebars made up out of steel tubing and then get them chromed.
daz_d_biker
PostPosted: 15:17 - 03 Jan 2009    Post subject: Reply with quote
The bars were bent on my dads monkey bike, we took all of the handlebar gear off and bent it back by sliding a long scaffolding bar on it and giving it some leverage.
Looks pretty good! get restoring now Very Happy
Pic whore:-
"bikes are replaceable - but a complete nutter aint."
thefallenange...
PostPosted: 02:42 - 04 Jan 2009    Post subject: Reply with quote
i miss 2t's. nice bike but defo need some shoes.
Past - CG125 ,KR1S, SV650s, Street Triple R - Current - Duke 390
[email protected]
hmmmnz
PostPosted: 04:51 - 04 Jan 2009    Post subject: Reply with quote
i love the kwaka monkeys, much better than the honda 4 strokes,
i was trying to buy one of those when i saw the mini buffalo,
i got the mini buffalo so cheap i just couldnt let it pass, plus, there is nothing like the feeling of rebuilding a bike that hasnt run for so long Very Happy
bare feet riding is where its at Very Happy
especially when it so hot at the moment Very Happy
i wouldnt ride anything bigger with no shoes Razz
the humans are dead
torpedo
PostPosted: 22:02 - 04 Jan 2009    Post subject: Reply with quote
Your bloody mad mr.hmmz, i wouldnt ride a pushbike without shoes!
Did you have to replace the crank or just clean it up a bit? Litterally was it just new rings?
GS 500 E ...... and i like it
The last post was made 17 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 138.84 Kb
