First time using SQl server and ADO. Help...?
Cigaro
PostPosted: 17:02 - 11 Nov 2008    Post subject: First time using SQl server and ADO. Help...? Reply with quote
Hi,
I have an Access 2002 application which I am converting to use an SQL server backend instead of a .MDB file. I've linked the tables fine, now I'm trying to work out how to change over all the ADO stuff.
This is the problem I have: Using the code below, I cannot get a recordcount - it always returns -1.
I know my cursor on the recordset is OK, is there something extra I need to specify on the connection object?
I know the connection ETC is OK as I can navigate between records, return record values and field counts.
Code:
Function TestODBC()
    Dim a As New ADODB.Connection
    a.Open "driver={SQL Server}; server={vista01\sqlexpress}; database={backend}"
    Dim b As New ADODB.Recordset
    b.Open "SELECT * FROM Contacts", a, adOpenDynamic, adLockOptimistic
    MsgBox b.RecordCount
End Function
PostPosted: 17:11 - 11 Nov 2008    Post subject: Reply with quote
If it returns -1, it may be that the property isn't supported.
https://www.w3schools.com/ado/prop_rs_recordcount.asp
The last post was made 17 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 32.3 Kb
