Clocks misting up...
Feasty
PostPosted: 15:33 - 12 Nov 2008    Post subject: Clocks misting up... Reply with quote
On my SLR650, the inside bottom half of the speedo mists up when its cold and wet meaning I can only really see the needle once it's above 30mph. Is there anything I can do about this or is it cause for concern at all?
Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed).
Renton
PostPosted: 15:36 - 12 Nov 2008    Post subject: Reply with quote
I may be wrong, but it sounds like it might not be sealed properly as it's letting moisture in?
This is my motorcycle. There are many others like it, but this one is mine.
Without me, my motorcycle is useless. Without my motorcycle, I am useless.
minesweeper
Whoah there!
PostPosted: 15:40 - 12 Nov 2008    Post subject: Reply with quote
Tape up around the glass and see if it still mists up, if it doesnt then reseal around the glass. If it does then try taping around the case, keep this up until it stops then you'll find where its letting moisture in.
If you've taped up every seal you can find and it still lets moisture in then get used to it Very Happy
Rvf400, 955i daytona, 954 fireblade, cbr1000rr fireblade 06 Hm plant
alun111
PostPosted: 17:28 - 12 Nov 2008    Post subject: Reply with quote
Also make sure the bottom half of the clock case it securely tightened to the top half. If it's easy enough to do - seperate the top from the bottom and make sure any rubber seals there are in good order.
UrbanRacer
PostPosted: 17:51 - 12 Nov 2008    Post subject: Reply with quote
get it sorted now before it causes the clocks to stop working, last thing you want is to go through a sh*t load of nonsense to buy new clocks and then have to get the mileage set.
Gazdaman
I did a trackday!!!
PostPosted: 19:14 - 12 Nov 2008    Post subject: Reply with quote
Pfft, just do more than 30.
And practically no-one sets the mileage if they change the clocks. Way too much effort. Just make sure you get clocks with lower mileage than the previous ones!
Gaz
The last post was made 17 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 47.41 Kb
