stubby cans
TAX MY BRAIN
PostPosted: 18:05 - 16 Nov 2008    Post subject: stubby cans Reply with quote
I was toying with the idea of stubby this can as its a bit to long for my 400 gixer,
now here's the thing is it as easy as it looks-
1) drill out rivets
2) remove end
3) cut to required length ( nice and straight of course )
4) replace end
5) redrill holes for rivets
6) rivet in place job done,
is it that easy, anyone done one before ??
i also ride the local bike.............she's like a moped great fun to ride as long as your friends dont see you !!
Ichy
PostPosted: 18:14 - 16 Nov 2008    Post subject: Reply with quote
Pretty much. Don't forget about the baffle, if it has one.
If its a real carbon can then you need to note that carbon fibre can splinter easily, the only way to cut it by hand is to use a fine tooth saw blade.
prawny1
PostPosted: 18:16 - 16 Nov 2008    Post subject: Reply with quote
the inner baffle (perforated tube) will need shortening aswell, if it straight through.
TAX MY BRAIN
PostPosted: 18:22 - 16 Nov 2008    Post subject: Reply with quote
oh yes its straight through as u can see in the picture, so no hassle with baffles,
picked up the can for £30 brand new from a bike breaker's bargin me thinks,
Noxious89123
PostPosted: 18:29 - 16 Nov 2008    Post subject: Reply with quote
I would of thought that tube *was* the baffle... Just a guess though, don't quote me on it, heh.
TAX MY BRAIN
PostPosted: 18:36 - 16 Nov 2008    Post subject: Reply with quote
im sure your right on that one,
would i be right in thinking the can is made from a carbon tube the baffle through middle and it's hollow inside and the 2 ends hold the tubes in place
Noxious89123
PostPosted: 18:55 - 16 Nov 2008    Post subject: Reply with quote
Couldn't give you a definite answer, but i'd have thought so. Hopefully someone will come along shortly and enlighten us both!
TAX MY BRAIN
PostPosted: 19:02 - 16 Nov 2008    Post subject: Reply with quote
or i could just get the hacksaw out and cut away n see whats in there,
but dont wanna balls it up so i'll hang on for someone in the know
MaybeGuy
PostPosted: 21:32 - 16 Nov 2008    Post subject: Reply with quote
ive just done 2 stubby cans, both of which came out pretty well... eventually.
the first was a twin outlet ART titanium can, sawed it in half. as i was shortening the bottom half, i had to pull out the innards, cut them down, then put it back.
in the end, i put it on, and it was as quiet as the stock can!!
looked down the end and all the packing had gayed up, and come out and into the can.
a few backfires and a MASSIVE cloud of fibreglass later, it was all clear, and as noisey as no can Cool
https://img139.imageshack.us/img139/8491/27102008087mq2.jpg
second one i did was a yoshi carbon fibre one that i shortened by 2" to get rid of the worn out bit at the bottom from various crashes, that one i measured properly, and made sure the inner was guided properly through the packing at the end.
no problems Thumbs Up (or pictures at the mo)
just take your time basically, and think about what your doing.
NiteMare
PostPosted: 23:33 - 16 Nov 2008    Post subject: Reply with quote
your can, can be shortened reasonably simply but you have to take your time and think about what you are doing ...
first off drill all the rivets out of both ends (might be better grinding the heads off and punching the remains out), then pull the caps off/out, the one cap should remove complete with the perforated tube ...
you may be able to remove the packing from the sleeve as well...
decide how much you want to shorten the can by and carefully cut the sleeve down (big jubilee clip around the sleeve to guide your cut), a dremell with cutting discs will cut it nicely (take your time)....
now you cut EXACTLY the same length off the perforated tube....
carefully cut the packing down to suit (very carefully)...
slip it all back together carefully...
now you are looking at drilling and rerivetting it, you'll want stainless steel blind rivets (3.5mm i think)if you use ally rivets you run the risk of it vibrating to pieces pretty quickly and turning into scrap...
take your time, look at what you're doing and you should get good results
it ain't broke...
i ain't fixed it enough
TAX MY BRAIN
PostPosted: 18:56 - 17 Nov 2008    Post subject: Reply with quote
great tips there nitemare thanks mate,
The jubileeclip idea sounds as if its gonna make life easier, think im gonna drill the heads off the rivets dont want to mark the end cap's with a dirty great grinder
will give it a go at the weekend along with plenty of tea drinking so i take my time , i'll post some pics n let ya know how i got on
The last post was made 17 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 73.79 Kb
