| Tazmcg |
 Tazmcg Derestricted Danger
| Noxious89123 |
 Noxious89123 World Chat Champion
 Posted: 18:30 - 16 Nov 2008 Post subject: |
Do you mean how to check and change the gear box oil, or the 2t oil for the engine? ____________________
'06 Honda CBR125RW-6 ~ '00 Honda CBR600F-Y ~ '07 Honda CBR600RR-7 ~ Bikeless
'53 Ford Ka 1.3 ~ '03 Vauxhall Astra SRi 1.8 ~ '52 Vauxhall Astra SRi 2.2 ~ '53 Vauxhall Astra GSi |
| nasty |
 nasty Traffic Copper
 Posted: 18:36 - 16 Nov 2008 Post subject: Re: How to Check & change 2 stroke oil |
| Tazmcg wrote: | Hiya everyone, i'm new to biking & have just recently bought a Honda NSR125 r. Can anyone please tell me how to check and change my oil, Someone told me i need to take the seat off first & move the tank back......how do i do that....please help? |
Unlock the lock under the rear left side fairing, pull down the lever behind the lock and lift the seat to release, take the seat off.
At the front of the petrol tank just under neath, you'll find a bolt with the head on the right handside, undo the bolt using a hex key, lift the tank carefully, you'll see a tank prop attached to the left side of the airbox, release this and prop the tank up with it, you'll see where it goes.
Once you done all the above you should be able to see the oil tank, the cap will clearly be marked OIL on top. Just unscrew and have a look inside. Don't think there is really any need to change as it gets burned. Just top up with good quality 2T oil (I use Castrol Power 1 TTS).  ____________________ ZX6R F3 |
| Tazmcg |
| Tazmcg |
| Moonie |
 Moonie World Chat Champion
 Posted: 09:40 - 18 Nov 2008 Post subject: |
Mkae sure you do it before it runs out, otherwise things break. ____________________ Don't practice it until you get it right, practice it until you don't get it wrong.
Presenting the one and only Chinkmobile  |
| truslack |
 truslack World Chat Champion
| nasty |
| MarJay |
 MarJay But it's British!
| truslack |
| nasty |
| robbo68 |
 robbo68 Borekit Bruiser
| truslack |
| robbo68 |
 Posted: 20:08 - 20 Nov 2008 Post subject: |
Yes it is more expensive if you buyit by the litre but the nsr only needs 700mls on an oil change so unless you don't mind payin £20 for 4lts and have it sitin around for ages you should go for the 4ltr tubs.  |
| TeddyCanuck |
 TeddyCanuck Nova Slayer
 Posted: 20:30 - 20 Nov 2008 Post subject: |
This light is difficult to test, and as such I wouldn't necessarily rely on it to govern your oil supply. If you run out of oil the engine will seize and you will have a LARGE repair bill.
The best method to test your oil light is let the tank run down to the last 200ml. Then wheelie, the light will illuminate. At least that's how I found out the light works. ____________________ Current Bikes: 1973 Honda Cl350k5, 1976 Honda PC50k1, 1981 Honda C70 (6V) Passport, 1982 Honda C70 (12V)Passport, 1984 C70 Passport, 1989 Honda NSR125F Adriatico 2. In CANADA try: https://www.import-motorsports.org/ for cool performance sport-bikes. |
| alains |
 alains World Chat Champion
| nasty |
 Posted: 20:53 - 21 Nov 2008 Post subject: |
Every time I fill my fuel tank I check the Oil and top up if neccessary ( "if neccessary"? I have to top it up every time I re-fuel ), I tend to go through about 1L of oil a month I think but the bike is in use daily. ____________________ ZX6R F3 |
| alains |
| TeddyCanuck |
 Posted: 19:32 - 22 Nov 2008 Post subject: |
Indeed Alanis.... My method, though fun, really isn't the best method  ____________________ Current Bikes: 1973 Honda Cl350k5, 1976 Honda PC50k1, 1981 Honda C70 (6V) Passport, 1982 Honda C70 (12V)Passport, 1984 C70 Passport, 1989 Honda NSR125F Adriatico 2. In CANADA try: https://www.import-motorsports.org/ for cool performance sport-bikes. |
The last post was made 17 years, 336 days ago. Instead of replying here, would creating a new thread be more useful? |
