Getting parts machined?
Quote Me Happy
PostPosted: 21:20 - 17 Nov 2008    Post subject: Getting parts machined? Reply with quote
After a bit of drunken ebaying I have some parts for my bike that don't really fit. However, with the Yanks being the ambitious chaps that they are, many of them have done the same thing and have kindly produced some drawings to help me out.
I'm putting a set of CR250 forks onto my XR. This seems a well documented process over on some Yank forums. I need to get a CR steering stem machined to fit into the CR yokes but accept XR bearings so it can fit the frame IYSWIM.
A chap over on Thumpertalk has produced these pictures -
Standard CR Stem
https://img.photobucket.com/albums/v619/baldgit/crstem.jpg
What the modified CR stem should end up like
https://img.photobucket.com/albums/v619/baldgit/crstemmodified-1.jpg
And a bushing needs to be made up to be pressed into the top yoke
https://img.photobucket.com/albums/v619/baldgit/toptriplebushing.jpg
If I took all the bits to a machining/engineering place would they know what to do from looking at those diagrams?
I also need the stem pressed into the bottom yoke and a bearing pressed over the stem and the new bushing pressed into the top yoke.
Would anyone like to give a rough estimate of the price I'd be looking at? As a total noob to stuff like this I don't know whether I'm looking at a £20 job or a £200 job.
Thanks.
Ariel Badger
PostPosted: 21:33 - 17 Nov 2008    Post subject: Reply with quote
The biggest problem is those threads, they are such an odd size (23.82 diam ffs!). If your machine shops has a die then it is relatively easy but I guess they will need screw cutting on the lathe. Even then the guy will need a female thread to try them into (fork leg?).
Cost... at a guess two hours work, £100.
Quote Me Happy
PostPosted: 21:37 - 17 Nov 2008    Post subject: Reply with quote
1930 Ariel wrote:
The biggest problem is those threads, they are such an odd size. If your machine shops has a die then it is relitivly easy but I guess they will need screw cutting on the lathe. Even then the guy will need a femail thread to try them into (fork leg?).
Cheers Ariel, I've heard the threads can be a problem.
There is a company in the US that sells a new aluminium billet stem and bushing for $180 (c. £120) + postage. That's looking more appealing now.
Plus I think every bloke appreciates a nicely machined lump of metal, even if it will be hidden from sight when on the bike, I'll know it's there Laughing
Ariel Badger
PostPosted: 21:43 - 17 Nov 2008    Post subject: Reply with quote
$180 looks cheap IMHO, the bushes look straight forward enough to make.
Bezzer
PostPosted: 21:45 - 17 Nov 2008    Post subject: Reply with quote
It isn't an odd thread size at all, it should be M24x1, being from a U.S. site they don't work much with metric and obviously don't realise a metric thread measures slightly under it's nominal size.
Ariel Badger
PostPosted: 22:12 - 17 Nov 2008    Post subject: Reply with quote
Right! so 25.83 is actualy 26mm. I still think $180 is a fair enough price
Ichy
PostPosted: 22:19 - 17 Nov 2008    Post subject: Reply with quote
Like Bezzer said, M24 tolerance is -0.05mm > -0.4mm. Mid point is -0.2mm which gives... 23.8mm.
I wouldn't think it would cost that much if you can get your hands on a CR stem, just some minor mods. The bushes are a few minutes work.
The last post was made 17 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 53.84 Kb
