| nsr125.98 |
 nsr125.98 Borekit Bruiser
| Kickstart |
 Kickstart The Oracle
 Posted: 20:32 - 25 Apr 2004 Post subject: |
The caliper is a floating caliper. You should be able to move it from side to side, but it will probably take a small amount of force.
The disk should not move from side to side. If it does then it is probably warped, but you would probably feel the front brake lever pulsing when braking, and the bike would not slow down smoothly.
If the front end is vibrating / oscilating then it is probably just the front wheel out of balance.
If the whole wheel is moving from side to side then it is probably the front wheel bearings that are gone. Check for any play in the front wheel (get someone to hold the front end of the bike off the ground, the you hold the front wheel at 3 o'clock and 9 o'clock and try and rock it, and see if you can feel a click).
It is also possible that the front wheel is buckled, but this takes a fair amount of force.
| nsr125.98 |
 Posted: 20:50 - 25 Apr 2004 Post subject: |
Thanks for the quick reply the actual caliper moves when im moving but not braking and the handlebars move slightly from side to side, also it pulses when i am breaking hard. thanks again for the help,
Gary |
| nsr125.98 |
 Posted: 21:01 - 26 Apr 2004 Post subject: |
i drove it to work today and the whole bike was shaking if i went over 25mph, got it checked and turns out that the rear wheel bearing had gone, the back wheel could move sideways .
anyway a couple of hours work and a tenner later its like new.
thanks gary |
| Kickstart |
The last post was made 21 years, 307 days ago. Instead of replying here, would creating a new thread be more useful? |
