04 CR125 gearbox oil change
Keir
PostPosted: 21:03 - 18 Nov 2008    Post subject: 04 CR125 gearbox oil change Reply with quote
just a case of pulling the sump plug and refilling i assume?
There is no sight glass or dip stick, that i can find anyway, do i just refill it with 650ml as is printed on the cases?
cheers
Current : '08 Yamaha FZ1s
2Smoke
PostPosted: 11:35 - 20 Nov 2008    Post subject: Reply with quote
yes, just like that. There may be a bolt that you remove to get the correct level reading from, usually 1/3rd of a way up the clutch cover casing near the filler cap, remove it then start filling with oil until it comes out of the bolt hole. May not have one though Smile
Keir
PostPosted: 12:16 - 20 Nov 2008    Post subject: Reply with quote
cheers, did it last night. Didnt find any level marker so i measured it in a jug. I'll check for a bolt as you say.
I emptied it and the oil came out graphite gray which i wasnt expecting. 800ml ish came out and i refilled with 650ml (as printed on cases) of rock oil gear oil, which was green.
2Smoke
PostPosted: 15:40 - 20 Nov 2008    Post subject: Reply with quote
The gray colour is usually aluminium in the oil, more than likely from the clutch. Not something to worry about unless you have chunks coming out!
Keir
PostPosted: 15:52 - 20 Nov 2008    Post subject: Reply with quote
definately no chunks. Thumbs Up
2Smoke
PostPosted: 01:40 - 21 Nov 2008    Post subject: Reply with quote
Ideal! Dropped the oil on a cr80 once and bits of 3rd and 4th gear came out with the oil Shocked
The last post was made 17 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 47.63 Kb
