| LeeR |
 LeeR World Chat Champion
 Posted: 09:26 - 21 Nov 2008 Post subject: Yet another lighting problem - sorted |
I'm beginning to dislike this bike very much as it's causing me so much grief.
As I was leaving work last night my head-lights stopped working, I have side-lights and full beam but nothing in-between. I turned the lights on and they had worked, as we have a long unlit tree lined driveway I put my lights oh hi-beam as I usually do. When I turned the hi-beam off ready to join the main road, the lo-beam went off as well.
I changed the bulbs and fuses which did nothing (as they weren't blown) and called recovery.
The recovery checked all the obvious things but couldn't fix it so he took me home, I worked on tracing the fault until midnight and gave up, the bike is currently in bits and in need my attention.
I've circuit tested all the connections breaking them down as far back as I can go i.e. to the loom, and testing the fuse mounts, all good.
So if it's not the switch-gear, block connector, bulbs, or fuse wtf is the problem?
Thanks in advance, again. ____________________ My claim to fame: Austin Vince nicked my pen...
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 10:11 - 21 Nov 2008 Post subject: |
| LeeR |
 Posted: 10:25 - 21 Nov 2008 Post subject: |
Yeah sorry, Suzuki DL-1000 K2 (V-Strom)
I've just re-read the wiring diagram and apart from the bulb, fuse, switch, and battery there is nothing else in the circuit.
The main beam circuit consists of 3 wires a common (B/W), lo (B/Bl), and hi (Y). Shorting these at the switch produces a consistent result that is, side-lights and hi-beam but no lo-beam.
What's doing my nut is the lo-beam circuit has to be complete for the hi-beam to work, so why does the hi-beam work but not the lo-beam? ____________________ My claim to fame: Austin Vince nicked my pen... |
| Finglonga |
 Finglonga World Chat Champion
| LeeR |
 Posted: 11:26 - 21 Nov 2008 Post subject: |
Yeah I have, I've even shorted the connectors on the back of the switch thereby by-passing the actual mechanism and still no good. ____________________ My claim to fame: Austin Vince nicked my pen... |
| Davo |
 Davo Davo To The Rescue!
| LeeR |
 Posted: 12:48 - 21 Nov 2008 Post subject: |
Yes I have higher rated bulbs in so much as I'm using Halfords Super Bright bulbs, however they are road-legal 55/60w.
I took them out last night and put the original bulbs back in, same symptoms, side and hi, but no lo.
I may be mistaken but there appears to not be a relay for the headlights, if there is it's hidden or not on the wiring diagram. I realise that sounds stupid because if there was a relay surely it'd be accessible and on the diagram.
I've used a multi-meter on the following points on the circuit and receive 12-16v: switch gear, block connector, fuse mounting.
Admittedly I haven't checked the head-light terminals, but I'm kind of deducing they're dead. I'm now wondering if there might be a small connector between the switch-gear and head-light plugs.
Thanks for the ideas, please keep them coming.  ____________________ My claim to fame: Austin Vince nicked my pen... |
| LeeR |
 Posted: 13:20 - 21 Nov 2008 Post subject: |
Found this on the VSRI forum: Headlights don't work it does not look promising, and may in fact be related to the indicator fault I had earlier in the month as it sounds like the L/H loom block connector is the culprit. All this means I've got to strip it all down again, and check the loom block connector...  ____________________ My claim to fame: Austin Vince nicked my pen... |
| LeeR |
 Posted: 21:38 - 21 Nov 2008 Post subject: |
Right I gave up and took it to the dealers, I'm now riding an '08 Suzuki GSF1250S Bandit courtesy bike.
They reckoned it'd be fixed within the hour, then I explained what I done and they said they'd ring me in an hour.
I rang them 2 hours later and they were still working on it, I'll ring them in the morning and see how it's going. ____________________ My claim to fame: Austin Vince nicked my pen... |
| rotax81 |
 rotax81 Nearly there...
 Posted: 22:33 - 21 Nov 2008 Post subject: |
the way i do it is start from the bulb and check every connector back from there until find power and thats where your problem is.
hope it gets sorted, electrical problems are a pain
 ____________________ ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol) |
| Ariel Badger |
 Ariel Badger Super Spammer
| LeeR |
 Posted: 12:37 - 22 Nov 2008 Post subject: |
Just got off the phone with the dealer they're still working on it, but have found the problem. It is as I thought the left-hand block connector, the female connection on the loom has burnt out.
They're going to try changing the block connector, but if it shorts again I'll need a new loom.  ____________________ My claim to fame: Austin Vince nicked my pen... |
| LeeR |
 Posted: 21:12 - 22 Nov 2008 Post subject: |
Right all sorted £105 lighter, and brighter  ____________________ My claim to fame: Austin Vince nicked my pen... |
The last post was made 17 years, 329 days ago. Instead of replying here, would creating a new thread be more useful? |
