| hush |
 hush Scooby Slapper
 Posted: 07:17 - 27 Apr 2004 Post subject: Changing the gearing ratios. |
Okay, don't know whether I'm just setting myself up for a job that isn't worth doing, but here goes...
The bike (Kawasaki KH125), is running nicely. Following a good clean up, and a little bit of aggressive acceleration in first and second for a few runs to clear out the system it has managed to go from the top speed of 60MPH (indicated) when I got it, to comfortably now reaching 65MPH (indicated) with a gear to go. Now if I let it crawl up to the 9K mark it will get to an indicated 69/70MPH with a gear to go. A quick up change sees it do one of two things:
Clutchless change: hovers at the 70MPH mark for a short time before slowly falling back to 65MPH
Clutch change: drops to 64/65MPH pretty instantly, and then usually down to about 60 by the time the engine has caught up.
Either way, if left running at full throttle in top gear, I end up at 65MPH again.
Now I'm not a speed freak (whilst on the road), and don't plan on being one - well at least until I can get my hands on a powerful machine - However, it would be nice if the bike could comfortably run at 70-75MPH (75 being the quoted top speed).
What I'm wondering, is if I can change the upper gearing on the bike (bearing in mind that it's being run on a CBT - and I'd like to remain legal), to give it a helping hand.
Also, any tuning tips would be greatly appreciated, I've scoured the Web, but I can't find anything on this bike that is written in English.
Finally (for those of you who haven't yet fallen asleep ), I noticed today that the rear brake (drum) is squeaking when the break is applied. Wasn't sure if it was just because of the torrent of rain last night (must buy her a cover), or perhaps something worse like wear.
Thanks peeps.  |
| Jammy-G |
 Jammy-G Banned
| G |
 G The Voice of Reason
| hush |
 hush Scooby Slapper
| hush |
 hush Scooby Slapper
 Posted: 13:31 - 27 Apr 2004 Post subject: |
Sounds like your top gear is too high a geared. Running lower gearing (as G suggested) might well make top gear more useable. However realistically I doubt you are going to get much over 70 as a top speed from the KH125, let alone have it capable of cruising at over 70.
The squealing from the drum is probably a build up of brake dust inside the drum.
| hush |
 hush Scooby Slapper
The last post was made 21 years, 307 days ago. Instead of replying here, would creating a new thread be more useful? |
