| Doddmaster |
 Doddmaster World Chat Champion
 Posted: 21:39 - 03 Jul 2002 Post subject: Noooo! |
After a great evening with Keith and Ann, my bike goes and breaks down
Hoping someone can help me out if I post the symptoms...
Anyways, I was caning the bike down a straight, changed into 5th (top) opened the throttle again and the bike just lost all power and started spluttering. Pulled the clutch in, stopped on the side of the road. Bike cut out, and wouldnt start. After a few kicks and some playing with the choke, it started. But it makes a clicking noise at medium revs, which wasnt there before and is quite worrying. I have lost power in the low range, and a chunk of the top end speed.
Anyone got any ideas
Cheers muchly,
Dodd |
| Doddmaster |
| Doddmaster |
| Doddmaster |
 Posted: 18:14 - 04 Jul 2002 Post subject: |
No oil warning light
What damage could have occured from an engine running without oil?? Cuz there really wasnt a lot in there at all |
 Posted: 18:43 - 04 Jul 2002 Post subject: |
Running out of oil can knacker most things. Likely to be the first to suffer would be the big end bearing, then piston and camshaft bearings (not sure if yours is overhead cam or pushrod, but a pushrod engine would probably get away with it for slightly longer before wrecking the cams). Run it really low and you would wreck the gearbox (and, frankly, the engine would be scrap).
Only real way to check the big end bearing is to take the top end off the engine and check for any vertical play in the con rod (a little side to side play on a 2 stroke is usual, but there should be no vertical play)
The importers web site is:-
https://www.symscooters.co.uk/
The 2 nearest dealers seem to be:-
Scooter Station
12-14 Castle Forgate, SHREWSBURY, Shropshire, SY1 2EE
(01743) 341211
Acorn Ford Chasetown
Queen St,Chasetown, BURNTWOOD. WS7 8XW
(01543) 685656
Might be worth getting hold of a gasket set and having a look
Keith |
| Doddmaster |
 Posted: 19:17 - 04 Jul 2002 Post subject: |
Cheers Keith
Yeah I used Scooter Station to get my speedo cable.
Anyway, I phoned up my mechanic and explained the symptoms. He immediately asked if it had any oil left. He said that it sounds like it had run out of oil and had a momentary seizure
He also said the damage is probably terminal, as I was riding it for another 15 minutes after it seized up.
Anyways, he cant have a look at for me over the weekend cuz is he racing, but he can probably have a look on Monday. Doesn't sound so good
Thats really annoyed me, even if it was my fault for not checking the oil |
| Robby |
 Robby Dirty Old Man
| Doddmaster |
| Robby |
 Robby Dirty Old Man
| Doddmaster |
| Keen |
 Keen World Chat Champion
 Posted: 20:00 - 04 Jul 2002 Post subject: |
unlucky dodd
unfortunately this stuff just seems to be part of biking |
| Annabella |
 Annabella Like a person, only smaller
 Posted: 21:08 - 04 Jul 2002 Post subject: |
Wheels not cursed! I only brain dmaged a rabbit on the way home with my boot!
Dodd!!! NNOOOOO!!!! ITs not fair!!! We'll get it sorted man....really ____________________ Avast! Pirates ahoy!
I did Cadwell!
www.bikepics.com/members/bella |
| Doddmaster |
| TiN |
 TiN Pocket Tin
 Posted: 22:07 - 04 Jul 2002 Post subject: |
I think number 3...plus stick "get a Ducati" on the end...
Tin |
| Doddmaster |
| M1ke |
 M1ke Ped Boi
 Posted: 22:17 - 04 Jul 2002 Post subject: |
find out the cost of fixing it first i would say. It may be worth your while fixing it so you can sell it at a higher price.
Sell scoot and bike once fixed (hopefully) then you have money for a ducati  |
| McJamweasel |
 McJamweasel BCF Junkie
| McJamweasel |
 Posted: 12:44 - 05 Jul 2002 Post subject: |
/me crawls under table in shame
Obviously I didnt hear that then  ____________________ BCF: Be yourself, just don't be an arse. |
| TiN |
 TiN Pocket Tin
The last post was made 23 years, 172 days ago. Instead of replying here, would creating a new thread be more useful? |
