| Bikeless |
 Bikeless World Chat Champion
| Kickstart |
 Kickstart The Oracle
| Bikeless |
| Kickstart |
| Bikeless |
| rotax81 |
 rotax81 Nearly there...
 Posted: 19:34 - 26 Nov 2008 Post subject: |
slightly quieter as in running weaker.
dude, you cant really gain a lot by messing with what you have.
go back to that last jet and basically do as keith said.
sometimes you can up the idle mixture a bit by the screws and it sorts some low down problems out but the idle will be a bit erratic when hot.
there is nothing like the right jet (the one you have)and the right needle height/shape to get it as near as dammit  ____________________ ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol) |
| Pete. |
 Pete. Super Spammer
 Posted: 20:00 - 26 Nov 2008 Post subject: |
Since dyno runs are full-throttle the mainjet size will do most of the work. Do a part-throttle run to determine the state of the mid-opening mixture and if it comes-out a bit rich say in the 12's put the 118 jet in a drop the float heights half a mil. ____________________ a.k.a 'Geri'
| Bikeless |
| rotax81 |
| Pete. |
 Pete. Super Spammer
 Posted: 20:07 - 26 Nov 2008 Post subject: |
Best to just use the idle mixture adjusment for adjusting the idle/small throttle openings. Using if to compensate for full-power mixture is asking for a headache. TBH I'm no carb expert, so I'll refrain from giving you advice that might be misleading.
Where in the country are you BTW? ____________________ a.k.a 'Geri'
| Bikeless |
| Bikeless |
| rotax81 |
 Posted: 20:35 - 26 Nov 2008 Post subject: |
from what i have read so far i would try the 122 jets and drop the needle to get the mid range back. basically as keith said somewhere above
then maybe mess with the idle mixture screws last. ____________________ ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
| Bikeless |
| Ariel Badger |
 Ariel Badger Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 21:46 - 26 Nov 2008 Post subject: |
Gotta remember though that the dyno graph will be all at full-throttle. ____________________ a.k.a 'Geri'
| rotax81 |
| Pete. |
 Pete. Super Spammer
 Posted: 22:09 - 26 Nov 2008 Post subject: |
Yes of course. Slides tend to open very early on full throttle though. ____________________ a.k.a 'Geri'
| Bikeless |
The last post was made 17 years, 321 days ago. Instead of replying here, would creating a new thread be more useful? |
