Author |
davec105 |
 davec105 L Plate Warrior
Back to top |
Kickstart |
 Kickstart The Oracle
 Posted: 22:13 - 27 Apr 2004 Post subject: |
Back to top |
davec105 |
Back to top |
Kickstart |
 Posted: 13:37 - 28 Apr 2004 Post subject: |
Guessing a bit here. You probably have a reserve switch for the tank. On the older bikes (and a presume your bike) the fuel pump is turned on and off by the cdi unit, using a sensor in the fuel tank. Basically when the fuel level drops the power to the fuel pump is cut, and the reserve switch bypasses the sensor.
Have a play around with this circuit. Might be worth just trying to switch it to reserve and try starting it like that.
Back to top |
davec105 |
Back to top |
Kickstart |
 Posted: 18:05 - 28 Apr 2004 Post subject: |
It would not surprise me if there is a circuit to cut the power the fuel pump after a short time. For example on my old FZ750 (which does have a reserve switch) the fuel pump only runs at full chat for a few seconds, then you have to flick the kill switch on and off. I presume this is to stop the pump running for too long when dry, and would assume there is a similar set up on your machine.
Sorry if this is no great help, but I have not worked on a bike like yours (YZF750 I assume). Stew might be able to help, or might have a workshop manual.
Back to top |
davec105 |
Back to top |
Kickstart |
Back to top |
Stew |
 Stew If it's good enough for top race teams...
 Posted: 19:57 - 28 Apr 2004 Post subject: |
I won't be a lot of help, but have you tried changing the fuel pump relay? I can hear my pump kind of buzzing when I turn my bike on with the key (along with the EXUP squeak) this also happens when I switch from 'on' to 'reserve' positions.
Last year I rode home from the Bulldog Bash (130 miles) with the fuel pumps electric connector disconnected. I didn't know this was disconnected and nothing was displayed on my rev counter, the bike seemed to run okay until around 100mph in top gear when it started to lose power.
AFAIK 7000rpm is a fuel level sensor fault, according to the Haynes you should check for continuity between the green and black wire terminals on the sensor side of the wiring with the tank the right way up.
<edit> I have just re-read your post and noticed you already have a haynes, so you will already know all that^ and also presumably if you replace the fuel pump you will have also replaced the sensor as it is all one unit</edit>
Sorry can't help really, it must be annoying though.  ____________________ "Unlike public school you don't need to have your arse up and your head down to go a long way...." |
Back to top |
Stew |
Back to top |
davec105 |
 Posted: 13:03 - 29 Apr 2004 Post subject: |
Yes it is the YZF750R.
I thought about the fuel pump relay, now and again, the bike seems to lose all power as if it is struggling for fuel, but when I pull in the clutch in runs fine.  |
Back to top |
tank |
 tank Nova Slayer
Back to top |
The last post was made 21 years, 111 days ago. Instead of replying here, would creating a new thread be more useful? |
