Inbuilt Indicators? LED
CrazyPassenge...
PostPosted: 19:37 - 02 Dec 2008    Post subject: Inbuilt Indicators? LED Reply with quote
Ello all,
Ive bought one of those inbuilt LED indicator/brake light kits for my ZX10R (04 model).
Ive gone to go and fit it last night and ive got a bit of a problem, the standed indicator connecters dont fit straight on to the new LED ones, theres only 2 wires coming out of the LED kit (one for the left indicator and one for the right).
The standed connecters are a block connecters, but have two wires going into each one (two for left, two for right). Therefore how do i go about fitting the new LED kit?
There is two little bullet connecters coming out of the wires, but ive tried plugging them into them and nothing happens Confused
... help!!! Sad
Smile Happy Days Smile Kawasaki 04 ZX10R ... an animal!
TAX MY BRAIN
PostPosted: 20:04 - 02 Dec 2008    Post subject: Reply with quote
im guesssing here but it sounds like the led unit ( brake light indicators ) is earthed from the brake light wires,
so should just be a case of finding the live indicator wires and wiring them in ,
bear in mind u may need to uprate the flasher unit as you are going from standard indicators to led,
please correct me someone if i am wrong
i also ride the local bike.............she's like a moped great fun to ride as long as your friends dont see you !!
Ichy
PostPosted: 20:07 - 02 Dec 2008    Post subject: Reply with quote
Sounds right to me. If they do flash too fast then its better to fit a relay than to use resisitors.
CrazyPassenge...
PostPosted: 20:09 - 02 Dec 2008    Post subject: Reply with quote
bear in mind u made need to uprate the flasher unit as you are going from standard indicators to led,
Yh thats what my mate thought, try and pull off the connecter block, and find the live wire for each indicator.
What would i do with the other wire, just tape it up, and out of the way? Confused
Only thing is if im wrong, then its a cunt to get the block back on! Very Happy Wink
Anyone actually fitted one of these things? Confused
CrazyPassenge...
PostPosted: 20:11 - 02 Dec 2008    Post subject: Reply with quote
Yhyh, there them little block connecter things you just plug straight in?? Stop them flashing too quick etc.
Ichy
PostPosted: 20:13 - 02 Dec 2008    Post subject: Reply with quote
Don't remove the connector block, either cut the wire behind the block and solder the wire, with heat shrink tube to insulate or find a connector that will fit into the existing fitting.
CrazyPassenge...
PostPosted: 20:17 - 02 Dec 2008    Post subject: Reply with quote
Ah right,
Ok cool cheers!
Is there anyway of checking it before i do cut it, check if it will work? Confused
TAX MY BRAIN
PostPosted: 20:21 - 02 Dec 2008    Post subject: Reply with quote
if you can get to the live wire in the plug use a piece wire between the plug and the new indicator wires before u cut ,
CrazyPassenge...
PostPosted: 20:40 - 02 Dec 2008    Post subject: Reply with quote
Cool,
Will have another look tomorrow, see if i can find the live wire!
Cheers pal! Thumbs Up
TAX MY BRAIN
PostPosted: 20:43 - 02 Dec 2008    Post subject: Reply with quote
good luck with it mate,
with the help off a volt meter u should find the live no problem,
Ichy
PostPosted: 21:51 - 02 Dec 2008    Post subject: Reply with quote
FWIW
Earth wires are generally black or black and white.
Live might be green or grey.
The last post was made 17 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 74.5 Kb
