Fine and 3 points...do I lump it or do I fight?
currykev
PostPosted: 15:30 - 01 Dec 2008    Post subject: Fine and 3 points...do I lump it or do I fight? Reply with quote
I got stopped for waiting in a bicycle-only box at traffic lights.
I was given a brief lecture, agreed with the offence.
I did not read the ticket I received at the time.
Offence traffic junction violation.
Asked to produce my docs at the local station.
Fine!
Now I have just come back from the police station and the offence/ticket states Traffic Light Violation. Code
The lady stated this is for running a red light????????????????
...and 3 points will also be added.
So do I fight this or lump it?
I am not happy!!! Mad
Hetzer
PostPosted: 15:36 - 01 Dec 2008    Post subject: Reply with quote
Fight it, all the way. Then appeal it if you lose. If you still lose, go out and do at least a grand's worth of damage to state property.
The only way to fight this kind of nazi BS is by direct miltant action.
Take a stand. If you're not prepared to do that, STFU, bend over and take it. It's as simple as that.
PostPosted: 15:42 - 01 Dec 2008    Post subject: Reply with quote
By using that area you have, legally speaking, jumped the red light. Not a hope you would win by taking it to court, you would just increase the fine and add costs.
Hetzer
PostPosted: 15:54 - 01 Dec 2008    Post subject: Reply with quote
Just the grand's worth of damage then.
PostPosted: 15:59 - 01 Dec 2008    Post subject: Reply with quote
Which does nothing, unless having done the damage you contact the state and tell them who you are and why you did it. Otherwise it just means an excuse for an extra grands worth of tax.
PostPosted: 16:01 - 01 Dec 2008    Post subject: Reply with quote
And make it count.
bikedemon99
PostPosted: 02:22 - 06 Dec 2008    Post subject: Reply with quote
If it was local cops they make mistakes all the time with traffic tickets, I got off with one once that was 6 points and £200 penalty, they put the wrong violation on the form and like I say I saw a lawyer and it was dropped, If its the traffic cops then chances are they got it right, speak to a lawyer its free for a first consultation I believe, good luck
Ride safe
yandy_yay
PostPosted: 09:07 - 06 Dec 2008    Post subject: Reply with quote
178
Advanced stop lines. Some signal-controlled junctions have advanced stop lines to allow cycles to be positioned ahead of other traffic. Motorists, including motorcyclists, MUST stop at the first white line reached if the lights are amber or red and should avoid blocking the way or encroaching on the marked area at other times, e.g. if the junction ahead is blocked. If your vehicle has proceeded over the first white line at the time that the signal goes red, you MUST stop at the second white line, even if your vehicle is in the marked area. Allow cyclists time and space to move off when the green signal shows.
[Laws RTA 1988 sect 36 & TSRGD regs 10, 36(1) & 43(2)]
fight it tell them the lights change as you approached and you could not stop sooner ! nowt wrong with that
HTH Andy
past bikes: (20 years ago) cg-125 (wriiten off), C-50 (thrashed n' finnaly scrapped), CZ-125 (nicked - never recovered, insurance payout was more than i paid for it !!!)
Current bikes: GN 125(now sold), Divvy 600s.
yen_powell
PostPosted: 12:29 - 06 Dec 2008    Post subject: Reply with quote
Also check that the marking is correct as per Traffic Signs Regulations and General Directions 2002, Diagram 1001.2.
Some I've seen haven't got a cycle lane leading into the cycle reservoire, which is a requirement.
Also some have no solid line joining the first and second stop lines.
Both of these make the cycle reservoir non compliant and technically unenforceable.
If there is no proper stopline, then the traffic signal post becomes the presumed stopline (for example at temporary signals or when the road is being resurfaced) which is of course in front of the cycle stopline.
From the regs below, note the undelined bit (my addition)
13. All vehicles are required to stop at any stop line when a red signal is showing, or, if they
can safely stop, an amber one. If an ASL is provided, all vehicles must stop at the
second stop line if they have already passed the first when the signal changes to red.
All ASL layouts are required to have an approach cycle lane, whether advisory or
mandatory
. If a red signal is showing, pedal cyclists may only enter the reservoir ahead
of the first stop line via the cycle lane. They may not do so by crossing the stop line.
Traffic authorities need to provide layouts that allow pedal cyclists to access the
reservoir via the cycle lane without being obstructed by other vehicles. The cycle lane
should be long enough for cyclists to bypass the queue of motor vehicles without
weaving. An advisory approach lane can be indicated by use of the markings to
diagrams 1057 and 1004 or 1004.1, without an upright sign to diagram 967.
XT1200Z and a DR350 in bits
The last post was made 17 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 63.67 Kb
