Probable fuel system/carb issues. Stumbling when riding.
4Stroke
PostPosted: 11:22 - 08 Dec 2008    Post subject: Probable fuel system/carb issues. Stumbling when riding. Reply with quote
Hey guys, I have an old ZXR 750 and lately as in the last week my bike has been idling very strangely, stalling at lights if I don't keep the revs up slightly but then idling fine a few minutes later.
I've actually witnessed the bike idle at 1.1k (manual recommendation for my bike) drop to 0.5k for a few seconds and jump back up to 1.1k intermittently.
Also the other day crusing along at about 80/90 on the motorway I had very bad carb/throttle stumbling problems and had to pull in to the inner lane, even then if I cranked it it didn't rev and started to stumble, and this occured at low speed with cranking open the throttle also when off the motorway.
I'm pretty competent at this stuff and I might even be able to answer my own question and say that I've been running it almost exclusively on reserve lately and have to say the reserve line in the tank never had a fuel filter so me and my father soldered one in albiet it was a bronze one off one of my dads BSA's so wasn't as fine meshed as the plastic one that was on the normal line.
I think what may have happened is alot of crap from the bottom of the tank has passed through this BSA metal filter we soldered on and probably clogged up the main inline filter and may have even passed through to the carbs but until I get the time to have a look I'm open suggestions.
Kind regards.
hmmmnz
PostPosted: 12:25 - 08 Dec 2008    Post subject: Reply with quote
clean out your carbs ect, usual shit,
my money is on valve clearances Thumbs Up
i had no end of problems on my zxr, stripped and rebuilt the carbs so many times it just wasnt funny,
turned out all of my clearances were too tight,
bastard of a job on a h1 or h2 to change the shims, very easy on the later models,
have fun :d
the humans are dead
I kick arse for the lord
4Stroke
PostPosted: 12:50 - 08 Dec 2008    Post subject: Reply with quote
have fun :d
Thanks for the reply. Yes so I've heard.
Though I'm still enclined to think fuel system since some days she'll fire up and be fine all day.
NiteMare
PostPosted: 13:26 - 08 Dec 2008    Post subject: Reply with quote
first thing to do would be to drain the float bowls, to make sure there's no water in them ...
then try the bike out again
it ain't broke...
i ain't fixed it enough
Smooth
PostPosted: 13:33 - 08 Dec 2008    Post subject: Reply with quote
Before doing anything with valves, I'd remove the carbs and clean them out thoroughly. I use a high pressure bicycle track pump to clean out jets and passages.
Then set float heights, check the pilot screws etc.
TDM850
4Stroke
PostPosted: 13:39 - 08 Dec 2008    Post subject: Reply with quote
Agreed.
Also whilst I think of it at the lights this morning a strong smell of petrol that I don't normally get a wiff off when stationary.
the grim reaper
PostPosted: 14:02 - 08 Dec 2008    Post subject: Reply with quote
Sounds like float height could be an issue, although that shouldn't change over time. Could be some crap is clogging the needle slide as well.
Clean carbs, check mixture screws and balance carbs, should do the trick.
Grim
4Stroke
PostPosted: 14:08 - 08 Dec 2008    Post subject: Reply with quote
Grim
Unlikey I set the float height a while ago to a slightly leaner mixture. Incidently before anyone points the finger no it's been running GREAT like this for months before the problem occourred. Laughing
4Stroke
PostPosted: 12:49 - 17 Dec 2008    Post subject: Reply with quote
An update, bike pretty much broke down just off the motoway last night (luckily)
It wouldn't rev past about 4k even not under load it just backfire to hell with some crazy flames out the exhaust.
Managed to get it home by keeping it under 4k and had a look this morning. Alot of rusty water in the 4 float bowls when I drained them.
Checked for pinches on carb rubbers and all seem to be opening and such ok.
Didn't have time to fully refurb carbs as had work at 11:30 but road it to work and running very good for the moment. No stumbling or idling issues either.
4Stroke
PostPosted: 13:31 - 17 Dec 2008    Post subject: Reply with quote
oh... well hopefully it was just that, and if you drained all the water ( as long as there wasnt any rust in the cabs ) it should be fine.
you might want to think about where the water came from though???
Pretty sure I know where, I have a motorbike cover that tore just when we had that massive downpour last week.
As a result the bike was sat through the pouring rain for a couple of days. Not only that but the fuel cap doesn't fit too tightly either as person who had it before me fitted some after market chav one. Crying or Very sad
The last post was made 17 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 65.58 Kb
