Aftermarket wheels and typre pressure question.
LuckyDip23
PostPosted: 12:49 - 11 Dec 2008    Post subject: Aftermarket wheels and typre pressure question. Reply with quote
would having aftermarket wheels fitted to a bike change the manufacturers reccomended tyre pressures?
also whats it better to go by - the trye pressue on the side of the tyre or the value in the haynes manual.
ta
gaz.
I have misplaced my pants.........
Derbi GPR 125 Nude (sold) ~ Yamaha YZF600R Thundercat (written off) ~ Suzuki GSX-R750 K2 ~ Triumph Speed Triple 1050 ~ Ducati Hyperstrada 821
Acemastr
PostPosted: 13:56 - 11 Dec 2008    Post subject: Reply with quote
each make and model of tyre needs a different pressure, once you're off the stock tyres that came with it the pressures in the manual are useless.
Sometimes the pressure on the side of the tyre only show a max load pressure, such as mine. mine say 32psi but that's far too high, but if you read carefully it says 32psi for maxload 150kg. If they are decent tyres you should be able to check online what pressure to have them at.
2016 Toyota Tacoma Limited
Finglonga
PostPosted: 14:13 - 11 Dec 2008    Post subject: Reply with quote
Wheels make no difference to the tyre pressures, stick with the tyre makers pressure.
Andy Sez....
F.Y.Y.F.F.
PostPosted: 14:19 - 11 Dec 2008    Post subject: Re: Aftermarket wheels and typre pressure question. Reply with quote
Not really (assuming the wheel is the same size and the same size tyres are used), although it might well affect suspension settings (most aftermarket wheels are lighter).
Totally ignore the pressure on the tyre. It is meaningless to your or probably any other bike. Only pressure there to take any notice of is the max pressure, but don't even think about running the tyre at that pressure instead of the recommended pressure for that tyre on that bike.
The last post was made 17 years, 304 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 41.23 Kb
