new bike..was curious..
conure
PostPosted: 15:45 - 01 May 2004    Post subject: new bike..was curious.. Reply with quote
got new bike, it was out the back on stand (gs125) and i was curious to try it, so i pulled the throttle and put it in first gear (to make the wheel move..) i left it running and A: dont know how to put it back to neutral, pushing down on gear thingy does nothing and B: the engine cut out and will only start with the choke on, and cuts out after running after about 20 seconds if it isnt revved, any advise as to what a stupid idiot who was too curious has done, would be appreciated (i know im stupid!)
conure
PostPosted: 16:20 - 01 May 2004    Post subject: Reply with quote
also in first gear should the wheel turn slowly on its own with no revving of the engine....
hush
PostPosted: 16:26 - 01 May 2004    Post subject: Reply with quote
The gear box from first to neutral is up rather than down. The gear layout will be something like:
5
4
3
2
N(eutral)
1
This means you push down to get to first, up a FULL stroke to second, or up a PART stroke to get to neutral.
I'm assuming you are now starting it in first, get it in neutral and see if that clears all problems first. There should be a light (often green) on the dash which will light when you are in neutral. Switch on the bike, but do not start then try to select neutral.
conure
PostPosted: 16:42 - 01 May 2004    Post subject: Reply with quote
okay, it doesnt mean ive broken it or anything does it? lol
Milo
PostPosted: 16:45 - 01 May 2004    Post subject: Reply with quote
Naa, you're all good mate. Smile
Gear order sounds ood at first but you get used to it very quickly.
Just remember - that little neutral light may lie occationally so always start with clutch.
Adam
Shaft drives rule. Razz
conure
PostPosted: 16:47 - 01 May 2004    Post subject: Reply with quote
okay i did it, its in neutral..but when i left it i left the fuel on, and the choke on so now it wont start at all, should i turn them off, leave it a while and try again properly?
G1_
PostPosted: 17:33 - 01 May 2004    Post subject: Reply with quote
Leave the fuel on. Not much point in turning it off. Push the choke back in. That would have flooded the engine. After 15 min or so it should be fine again.
PostPosted: 17:39 - 01 May 2004    Post subject: Reply with quote
Do turn the petrol off. If the bike has a leaking needle valve then it will flood while it is parked. Turning the petrol off limits the amount of fuel that can leak past the needle valve.
G1_
PostPosted: 17:45 - 01 May 2004    Post subject: Reply with quote
I've never really had the above problem. I had heard that it happened but thought it was people just being over cautios. Maybe I'm wrong then...
conure
PostPosted: 17:59 - 01 May 2004    Post subject: Reply with quote
been an hour, still wont start, fuel is off now...it tries to start but fails
conure
PostPosted: 18:24 - 01 May 2004    Post subject: Reply with quote
so why wont it start now? my uncle on the phone thinks its flooded, but its been over an hour..
Noggin
PostPosted: 19:02 - 01 May 2004    Post subject: Reply with quote
Make sure you turn the fuel back on when trying to start or run the bike, otherwise there is no fuel to ignite!
Just turn it off when its not on
Craig G(Noggin)
Current bike: kawasaki zx12r 2002
Track bike: yamaha r6 1998
Old Bike: honda NSR 125 1998
mrchips
PostPosted: 19:52 - 01 May 2004    Post subject: Reply with quote
If the bike is flooded, put it in neutral and try starting it with full throttle, it should start after a few attempts. The other alternative is to bump start it. Put it in 2nd and run along and let the clutch out.
conure
PostPosted: 20:40 - 01 May 2004    Post subject: Reply with quote
it still doesnt work, ive been told to leave it over night to let it unflood, might that work?
RSixer03
PostPosted: 21:08 - 01 May 2004    Post subject: Bump start it..... Reply with quote
Have a go at bump starting the bike.........so get a little speed up jump on the bike flick the gear into 2nd and let the clutch out......VIOLA Thumbs Up
"If everything seems under control, you're just not going fast enough."
Mario Andretti.
PostPosted: 21:27 - 01 May 2004    Post subject: Reply with quote
Generally you will not have such a problem. It is quite rare, but when it does happen it is a total pain. The Bandit did it once when I left the petrol on "prime". Overnight it dumped over 12 litres of petrol through the carbs into the airbox and engine.
Maybe. If you are doing this then take out the spark plug which will allow the fumes to get out more easily (just don't smoke near it).
conure
PostPosted: 21:39 - 01 May 2004    Post subject: Reply with quote
is the spark plug the big white thing?
conure
also, if this isnt it..whats wrong?
PostPosted: 22:02 - 01 May 2004    Post subject: Reply with quote
The spark plug goes in to the top of the engine. It will have a cap covering most of it. The cap is probably either black rubber, or dark red plastic with a rubber cover at each end. A thick (5mm diamter) cable will lead from this cap up to the coil (which is probably hidden from view.
If you take the cap off you will find the plug. The bit that will then be visable will be about 2" long. The bottom bit will be metal, with a hex shape (for a plug spanner), with the upper bit being a white porcelain. At the very top there will be a little bit of metal or a little bit of threaded metal.
Hope that describes the spark plug for you.
I would say that 95% likely you have flooded it, and quite probably that is you lack of technique starting it (don't worry, you will get better), made worse by starting and stopping it quite often, plus over using the choke.
conure
PostPosted: 22:21 - 01 May 2004    Post subject: Reply with quote
okay well now i have another problem, upon trying to start the engine the light dims, there is a light that illuminates the rev counter, but not the speedo, and the engine fails to kick in at all, theres a new battery in the bike and it just passes its mot, i dont know what to do Sad first day i got it and it wont work
mrchips
PostPosted: 22:36 - 01 May 2004    Post subject: Reply with quote
Turn your lights off before starting as this drains a lot of power from the battery. Some bikes headlights brighten according to how hard they are being revved. Get someone you know with experiance of bikes to come round and show you basic techniques of starting etc that would probably be best to help you.
bikedudextrm
PostPosted: 22:42 - 01 May 2004    Post subject: Reply with quote
Dont give the bike any throttle when you start it, this is where i went wrong when i first got my bike.
conure
PostPosted: 07:01 - 02 May 2004    Post subject: Reply with quote
i think i should take it to a garage..i dunno what to do at all lol
PostPosted: 12:37 - 02 May 2004    Post subject: Reply with quote
I will second that. Only give it throttle once it has caught. If you find yourself twisting the throttle as you kick it over then try holding the handlebar just inboard of the throttle, or hold on to the mirror stem.
AcIdBuRnZ
PostPosted: 15:24 - 02 May 2004    Post subject: Reply with quote
Have you been sitting with the engine running and all the lights on? Shocked
This will drain the battery pretty quickly since it is using more power than is being put back in... I did it on the NSR, went out one cold morning to warm it up before heading out, left it running with lights on and 20mins later it died and wouldn't start, and it's hard jump starting with a loaded back pack on in the cold on flat ground, believe me!!!
Now I get into that habit of killing the lights whenever I park, so I won't leave them running next time I start it.
Mark
The last post was made 22 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 124.69 Kb
