Changing gear without clutch
Doovy
PostPosted: 22:55 - 11 Dec 2008    Post subject: Changing gear without clutch Reply with quote
I think i read on here, in the past few days, that it is possible to change gear without the use of the clutch.. it went something along the lines of
"rev highly in the gear, close the throttle fast while pushing up on the gear lever and re-engage the throttle and the gear will change up"
can someone explain how and why this works to me please? ive been doing it a few times recently on motorway to save pulling in the clutch, is it damaging to the bike at all?
and i cant for the life of me remember where i read it!
thanks
Dave
Alex-RS
PostPosted: 22:59 - 11 Dec 2008    Post subject: Reply with quote
It's not damaging as bikes have sequential gearboxes.
https://auto.howstuffworks.com/sequential-gearbox.htm
Clutchless gear changes have their advantages, if you get it right.
Mil17b
PostPosted: 23:32 - 11 Dec 2008    Post subject: Re: Changing gear without clutch Reply with quote
thanks
Dave
You don't have to close the throttle, just a tiny little flick of less throttle whilst changing up.
dunc4230
PostPosted: 23:34 - 11 Dec 2008    Post subject: Reply with quote
what they say but dont change down or you will f**k up your gearbox
https://www.speedtest.net/result/119878199.png
https://z3.invisionfree.com/Bikers_On_Board/index.php?act=idx
Faldo
PostPosted: 23:58 - 11 Dec 2008    Post subject: Reply with quote
I always change up or down through the box without using the clutch. Never had any gearbox issues.
Current: ZZR1400
Acemastr
PostPosted: 00:07 - 12 Dec 2008    Post subject: Reply with quote
i've done it a few times, i find the bike jumps when i upchange which makes me look like a tit. and remedies?
2016 Toyota Tacoma Limited
Faldo
PostPosted: 00:09 - 12 Dec 2008    Post subject: Reply with quote
Is it when you are shifting from 1st to 2nd at fairly low revs?
Current: ZZR1400
D O G
PostPosted: 00:28 - 12 Dec 2008    Post subject: Reply with quote
Only time I ever use the clutch is this situation. Is difficult to get a smooth change in these circumstances.
Faldo
PostPosted: 00:31 - 12 Dec 2008    Post subject: Reply with quote
Me too, other than if I'm doing some heroic engine braking. Laughing
Current: ZZR1400
Acemastr
PostPosted: 00:46 - 12 Dec 2008    Post subject: Reply with quote
No, clutch always for that, it's every other gear, no matter what revs
frez
PostPosted: 10:01 - 12 Dec 2008    Post subject: Reply with quote
Once road all the way from London to Dorset without a clutch, only realised when approaching the first roundabout on the A31, then nursed it the rest of the way timing entry and keeping fingers crossed at every junction. A bolt attaching the throttle cable to the engine had come loose (had been serviced the week before at a main dealer!).
bEN_
PostPosted: 23:11 - 12 Dec 2008    Post subject: Reply with quote
You can change up or down without the clutch, you just need to do it right, if your on an old R6, your screwed whatever you do Laughing
changing down without using the clutch isn't really helpful on the roads though
2010 Ducati 848 Dark
Lamp Post Enthusiast
Acemastr
PostPosted: 00:34 - 13 Dec 2008    Post subject: Reply with quote
can anyone shed some light on why my bike jerks violently when changing up in any gear at any revs (i don't do 1st to 2nd)
m0l0t0v
PostPosted: 00:39 - 13 Dec 2008    Post subject: Reply with quote
You're probably not doing it right.
Acemastr
PostPosted: 01:13 - 13 Dec 2008    Post subject: Reply with quote
handy tip there :p
say for example i get to 8.5k rpm, apply slight pressure to the gear shifter, flick wrist forward, lift foot, flick wrist back.
didn't think there's anymore to it?
m0l0t0v
PostPosted: 01:18 - 13 Dec 2008    Post subject: Reply with quote
Razz
You're probably not getting the throttle on time with the gear shifting. It has to be done really quick. If you don't do it quick it would probably jerk forward like you mention.
Try being faster Wink
TheDonUK
PostPosted: 01:44 - 13 Dec 2008    Post subject: Reply with quote
And dont flick your wrist forward just ease off a bit, i find that the moment you are not actually accelerating it will slip up into the next gear pretty simply...
mooserx
PostPosted: 10:25 - 13 Dec 2008    Post subject: Reply with quote
no clutch gear changing rocks, i find you can get better acceleration if you do it right, as with most things in life, it's the timing thats important.
TL1000r-handful.
bEN_
PostPosted: 12:52 - 13 Dec 2008    Post subject: Reply with quote
Just get a quickshifter.
no one gives a fuck about the fact it gains you so many yards with a few easy changes it just makes the damn thing easier to ride.
thx1138
PostPosted: 02:58 - 15 Dec 2008    Post subject: Reply with quote
I rode a TS-125 20 miles home without a clutch once.
I tried to ride a KM-125 home in 6th gear when the gear stick fell off.... Embarassed that didn't work out so well. Laughing
magpiemale
PostPosted: 17:19 - 15 Dec 2008    Post subject: Reply with quote
Damn right.
You should use clutch less changes for 4th,5th and 6th but not for 3rd and below ie:when in third gear roll off the throttle (no need to rev the bike as to much rev's will make the gear not slid in ) and gear up without the clutch but do make sure you have 4-5000 on the revs or more as below this will make the bike kick or jump and also true if you have far to many rev's like 8000 plus as the bikes power will jump in when you change up thus making the bike jump,it's not rocket science as I am thick but I can do it.Just practice it some times even the best rider makes mistakes.
It also depends on your bike to as to the rev's as some like mine have good rev's low down in the gears while race bikes have their rev's in the high end
NSR125 1992 (sold) kawasaki Z750S,fazer FZ1 07 now gone present bike 2012 fz1s Fazer,beowulf rad protector,heated grips,sw motech gps holder,power socket.
repsolblade
PostPosted: 17:29 - 15 Dec 2008    Post subject: Reply with quote
try doing a trackday using your clutch for every change, you'll have a forearm like popeye.
or wankers cramp after 1st session Shocked
( TS50 RD80Lc RD125Lc CBR600 ZX7x2 SP1 CBR900 CBR1000rr GSXR750 CBR600)
Clansman
PostPosted: 14:32 - 18 Dec 2008    Post subject: Reply with quote
Just the kind of thread I was looking for. Thanks for shedding light on it - I wasn't sure if current bike gearboxes were sequential or just a different weird kind.
Being sequential, they are designed to change gears without de-clutching. In fact, some gearbox manufacturers even argue that using clutches between gear changes in sequential gearboxes actually damages the cogs further than if not using it... seems weird at first...
Theoretically, all that's necessary is to cut the load from the engine to the gearbox and it will happily change gear if you tell it to. [To cut the load is actually very different than to cut the throttle]. I reckon it should jerk a little even if done perfectly right because the moment the gear changes, the engine keeps its revs, the wheels keep their speed but you're changing their ratio, so they *will* have to adjust and that will be felt by the rider.
This involves (as already discussed) lowering the throttle slightly so that the engine neither pulls nor slows the bike. In a small rev interval around that spot, the gearbox will change gear. Both in cars and in bikes, this can be eased by applying a bit of pressure on the gearbox lever while lowering the throttle. With a bit of practise, it will go well.
Actually, synchro meshes allow us to do a similar thing in our cars' manual 'boxes. If done right, it's perfectly smooth Thumbs Up. If done wrong, there's this horrible crank noise that makes everyone look at you and you feel like a n00b that forgot to de-clutch Rolling Eyes, hehehe.
I've read a Hewland gearbox manual (seq, for cars) in which they explained that the correct technique for changing gear *should not* involve the clutch.
I'm not a specialist, just curious, so I may be wrong.
Cheers guys,
Pedro.
The last post was made 17 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 123.28 Kb
