Engine coolant
 Topic moved: from General Bike Chat to The Workshop by G (3 May 2004 - 22:55)
True Blue
PostPosted: 16:49 - 02 May 2004    Post subject: Engine coolant Reply with quote
Might sound like a stupid question but should I check the coolant level when the engine is hot or cold?
The reason I ask is that I thought the level on my bike was low as it was way below the low level mark. I then started the bike up and left it running for a while and I noticed that the level had risen and it was now sitting between the high and low level mark.
Is this right?https://pages.prodigy.net/indianahawkeye/newpage22/14.gif
Another thing. At what temperature should the radiator fan kick in?
Ritchie. Thumbs Up
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
Dup
PostPosted: 17:04 - 02 May 2004    Post subject: Reply with quote
When its cold. You will see lots of warnings!
Fill it to between the high and low levels. They aren't at the top for a reason you've just said. It pushes back up to the top. So over-filling could lead to a bit of a bang and hot liquid everywhere.
Should i just put water in my DNA's?
PsychoHippy
Jammy Git
PostPosted: 04:22 - 03 May 2004    Post subject: Reply with quote
Always check it when the engine is cool. When it warms up the liquid expands - it's physics you see Wink
As for the fan, that changes from bike to bike. The V-Raptor fan comes on at about 98 degrees, but the Benelli fans kick in at about 90 degrees.
I spend all my money on bikes and beer, the rest I simply waste!
True Blue
PostPosted: 10:08 - 03 May 2004    Post subject: Reply with quote
Yeah, that's what I though. Just thought I'd check.
I'm a wondering how it's so low though. It was serviced 1000 miles ago, so I'm assuming it was at the correct level then. I don't see any signs of a leak Thinking
So is there any particular coolant I should use?
I expected it to be about 90. I was just wondering. cheers Thumbs Up
True Blue
PostPosted: 21:06 - 03 May 2004    Post subject: Reply with quote
Right, here's another schoolboy question.
The antifreeze in my bike is greeny blue ish and the stuff I got from Halfords is red, What's the story there Neutral ?
What colour should it be?
mr jamez
PostPosted: 21:19 - 03 May 2004    Post subject: Reply with quote
Well I have never come across red antifreeze, however anti freeze is anti freeze you mix it with water and bung it in Laughing are you just topping the cooland levels up? if so I would just put water in if it is only a little bit low.
True Blue
PostPosted: 21:20 - 03 May 2004    Post subject: Reply with quote
topping it up but it's way low so I was going to mix some up
PsychoHippy
Jammy Git
PostPosted: 22:07 - 03 May 2004    Post subject: Reply with quote
If it's really low, then mixing some of the new antifreeze with it will be fine.
You would get away with just using water at this time of year anyway, but you would need to remember to put some antifreeze in before winter comes aroud Confused
PostPosted: 23:51 - 03 May 2004    Post subject: Reply with quote
Anti freeze also contains corrosion inhibitors, which are rather important in an alloy engine.
PsychoHippy
Jammy Git
PostPosted: 00:32 - 04 May 2004    Post subject: Reply with quote
Ah yes, a good point that I had overlooked Embarassed
mr.z
PostPosted: 00:59 - 04 May 2004    Post subject: Reply with quote
Mate of mine runs his trike with neat coolant, never had a problem for years.. not tryed it myself but interesting yes?
The reason you should be EXTREMELY careful when checking the coolant level if its warm is... Your cooling system is presureised, the coolants boiling point is raised (say from 100 to 200 or something??) so when you depresureise the system the boiling point lowers again so when you take the cap off the coolant boils and is generally not a good thing.
As for colours, they do make it in different colours, if your changing your coolant it is good to know when you have old or new coolant coming out, maybe?
One other thing, make sure to use de-ionised water, normal tap water will do your cooling system/waterpump/pipes no good at all...
True Blue
PostPosted: 19:28 - 04 May 2004    Post subject: Reply with quote
Cheers all. I've got my distilled water and pink antifreeze. SO your saying it's alright to mix then/? The colour doesn't indicate a different type then?
This is the stuff I bought. Anyone used it?
PostPosted: 22:49 - 04 May 2004    Post subject: Reply with quote
Some bikes have water pumps that will not work with such a thick fluid as neat antifreeze. You will land up with the radiator being cold while the engine is overheating.
Hex
Party Boy
PostPosted: 11:20 - 05 May 2004    Post subject: Reply with quote
As Keith has said it could cause a problem if its too thick for the water pump.
If he's buying the pre mixed stuff thats not a problem then, but I would never run neat anti freeze as one its not really going to give you any benefits, two it could in-fact cause problems and three bit of a waste of money considering they design the stuff to be watered down in the first place.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
The last post was made 21 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.65 - MySQL Queries: 16 - Page Size: 87.1 Kb
