Carb icing or not?
Drew This post is not being displayed because the poster is banned. Unhide this post / all posts.
MaybeGuy
PostPosted: 23:02 - 14 Dec 2008    Post subject: Reply with quote
ive got the same bike, same problems.... yes, its carb icing.
Whosthedaddy
PostPosted: 23:04 - 14 Dec 2008    Post subject: Reply with quote
Had it a couple of times this year, bikes fine until slow down or pull up at some lights and its like a bag of spanners.
PostPosted: 23:08 - 14 Dec 2008    Post subject: Reply with quote
Does it fix itself if you stop for a short time?
Whosthedaddy
PostPosted: 23:14 - 14 Dec 2008    Post subject: Reply with quote
Mine continued for the next 5-10 minutes I suppose of stop start riding.
I've been in colder and damper temps with no real problems?
sickpup
Old Timer
PostPosted: 23:21 - 14 Dec 2008    Post subject: Reply with quote
So explain why it doesn't happen at high revs when the vacuum is at its highest and the inlet charge is at its coldest?
MaybeGuy
PostPosted: 23:27 - 14 Dec 2008    Post subject: Reply with quote
explain why it only happens when its really cold Wink
PostPosted: 23:32 - 14 Dec 2008    Post subject: Reply with quote
Carb icing requires cold and humid weather. Too cold and there is not enough moisture in the air for carb icing to occur.
andys675
PostPosted: 23:33 - 14 Dec 2008    Post subject: Reply with quote
buy some silkolene pro boost and say goodbye to icing
PostPosted: 23:43 - 14 Dec 2008    Post subject: Reply with quote
Drew wrote:
As Sickpup says, high revs, high speed, there is no problem
High revs you are on the main jet, and that should be less inclined to block due to the movement of the needle (it will still get blocked, but takes rather more than to block the tiny idle jet).
On my FZ750 it would suffer from carb icing in cold damp weather (normally fog). At high revs it would feel OK, but would use about twice as much fuel (would drop from 45mpg to 25mpg). Suspect the buildup of ice prevented the slide from closing.
PostPosted: 00:02 - 15 Dec 2008    Post subject: Reply with quote
Carb icing problems come from the water vapour in the air freezing and building up in the carb. That might block a jet or jam the slide.
On a CV carb (ie, most carbed 4 strokes) the mixture for most of the rev / throttle range is controlled by the needle jet. The needle part of this is mounted in the slide, and the slide moves itself depending on intake vacuum. More vacuum means the slide moves higher, meaning a narrower bit of the needle is blocking the jet. So if the slide sticks higher up then the mixture will be FAR richer.
sickpup
Old Timer
PostPosted: 00:18 - 15 Dec 2008    Post subject: Reply with quote
Thing is the SRAD has the carbs in a pretty good position to take heat from the engine to prevent carb icing.
As Phantomtek discovered they have tiny little filter in the fuel hose where it joins the carb that block up very easily, no one ever changes them.
Worst of all they seem to be a bike that everyone pisses about with so the fuelling is never right which causes a lot of problems.
I hate it when it gets cold, every running problem gets put down to carb icing yet none of my bikes seem to suffer from it no matter how cold (or moist) it gets.
D O G
PostPosted: 00:47 - 15 Dec 2008    Post subject: Reply with quote
Since it was my thread to start with, I'll tell you what was acutally wrong with the bike (after much investigation, part changing etc). The fuel pump cutoff was dodgy, which meant that it kept pumping too much fuel in on low revs, but ran fine at high revs as the fuel was needed.
This caused #2 carb to be flooded all the time, as it is nearest the fuel inlet pipe. The problem became progressively worse until it wouldn't run at all at low revs, became impossible to start and it went to a garage and someone who knew what they were doing looked at it.
Think people (like me) like to blame carb icing, since it is one of those 'phenomenon' problems, which is an easy explanation for shit running, when in fact there is just something wrong with the setup or a faulty part in the bike.
I'll say this though, even after it was fixed and apparently setup on a rolling road it ran lumpy at low revs. My 91 FZR 600 pulls smoother than the SRAD ever did. I don't know whether this is a common problem with the bikes, or that the skills of setting up a carbed bike are dying.
ben_wheely
PostPosted: 14:30 - 15 Dec 2008    Post subject: Reply with quote
I have this problem too (DRZ 400). Only on really cold nights/mornings, it cuts out on low revs/idle, but rides fine once moving.
When it cuts out, its pretty quick to start back up again - providing i give it some throttle.
Changed my plug last week, and noticed that my bike is running rich. But i had a slightly corroded HT wire, so that may of been the cause of my black spark plug.
The HT wire was cut back to a good bit, and a new plug fitted, and still in the cold it cuts out ?
Oh, and by the time i get to work (20-25 mins of town riding) it idles fine ?
Is this carb icing ? Sorry for hi-jacking your thread.
Rides: '05 Yammy WR290-F
PostPosted: 14:52 - 15 Dec 2008    Post subject: Reply with quote
Could just be that it is lean at idle. Carb icing is highly unlikely to be the cause if it happens from cold, as carb icing is caused by air / fuel taking the heat from the carb body, so that water condenses and freezes on the carb body. Hence it needs a bit of time at a fair speed before the problem will occur.
Would probably only take a couple of minutes of low speed riding / idling while blipping the throttle to clear the icing as well.
NiteMare
PostPosted: 17:15 - 15 Dec 2008    Post subject: Reply with quote
slightly off angle here ....
the only time i've ever experienced carb icing was in an old volvo 145 estate, single stromberg carb on a 2litre push rod engine, it turned out that water had collected in the airbox to carb joint and as the airstream was flowing over it , it sucked vapour over the jets which then solidified ....
of course we'd pull over going WTF!! and it'd start again within seconds, which had us baffled for a day or so (engine heat melted the ice)..
i eventually started to take things apart to try and suss the problem and spotted the puddle (about 2 tablespoons full) drained that off and the problem was cured (luckily it didn't spill without me noticing or i'd have hunted for quite a while and took more to bits than needed)...
all this was in the early summer, i've no idea how the water had got there but once it was gone the problem was solved
it ain't broke...
i ain't fixed it enough
sickpup
Old Timer
PostPosted: 19:39 - 15 Dec 2008    Post subject: Reply with quote
Drew wrote:
I'll take a look at this at the weekend, but as said, the bike has been fine all the rest of the year, this only happens with temperatures like we have now. Strange.
You mean when its cold, and the air is denser?
So what modifications does your bike have?
PostPosted: 19:52 - 15 Dec 2008    Post subject: Reply with quote
Drew wrote:
Arrow exhaust
K&N filter (doubt it does anything, but was in when I got it)
Both of which might lean the mixture out a touch. And in cold weather the air is more dense and so it leans the mixture out even more. And a cold engine needs a richer mixture anyway.
Find the idle mixture screws and richen the idle mixture up a touch and see if that fixes it.
The last post was made 17 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 135.69 Kb
