| Visitor Q |
 Visitor Q $25 whore
 Posted: 18:01 - 15 Dec 2008 Post subject: Running (badly) on choke, and stalling without |
Hey all, my CBR 600 FT (1996) seems to be dying
I've had this rattle for a fortnight or so which hasn't seemed to affect the actual performance.
Now out of the blue the bike died by the end of my road. Sounded like fueling difficulties so I chucked it onto reserve (about 20 miles earlier then normal) and then it still wouldn't run properly.
It would raspily run with the choke fully on, but sounded abit like it was oil seizing (I've checked that and the level is fine*) and wasn't exactly generating power. Soon as the choke went off it would stall within a few seconds.
Can all that be ascribed to loose headers/manifolds? As that's what I'm pretty sure I'm dealing with. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
From September 2014 to January/February 2015 I will not be using any English, nor reading any. As such, I won't be on here. PM at will, but I won't be checking/posting unless in emergencies. Certainly not for the first couple of months. Please berate me savagely if I break that rule... |
| m0l0t0v |
 m0l0t0v World Chat Champion
 Posted: 18:26 - 15 Dec 2008 Post subject: |
I had something like that happen with the Hornet ages ago. The actual problem was just a screwed up tube.
From the fuel tap feel the small tube for any rips or tears. It should go from the tap to the back of the cylinders. Found the problem was that it had tarnished at the end. All I had to do was cut it slightly and put it back in. This little tube created pressure and "pulled" the diaphragm of the fuel tap and let petrol flow. No harm in checking and it takes like 1 minute. I was also off the road because of that little dick for a month
My Hornet at that point would run on choke but if youi took it off it would die. And it did sound like fuelling problems (which it was)
Could also check to see if petrol is getting into the carbs? ____________________ '99 Hornet 600 , VFR 400 NC30 '92 , Kasawamasaki GT 550 , '98 Hornet 600
**\Tarmacsurfer/** said: It's that immaculately manly coiffure of yours isn't it. One glimpse of your virile locks and the punters can't wait to buy whatever it is you suggest, as it might let them be just a little bit like the Adonis that is our very own Molly Doovydoo said: Its not my fault I can't get it up properly, I just wasn't blessed  |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 18:32 - 15 Dec 2008 Post subject: |
I really should learn to do more bikey things. Haven't 'checked' my carbs in the 3 years I've owned it (nearly 4 now).
Will check the fuel tank hoses, but can't help thinking it's related to the rattle  ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| m0l0t0v |
 Posted: 18:53 - 15 Dec 2008 Post subject: |
I never checked them either unless I had to drain the diesel and the time the pipe had tarnished.
I can't comment on the rattle though.. But checking to see if the carbs have petrol in (by usng the drain screw) and checking the pipes takes literally a couple of minutes and you can cross fuelling problems of your list or be safe in the knowledge it's jut a pipe which is cheap.  ____________________ '99 Hornet 600 , VFR 400 NC30 '92 , Kasawamasaki GT 550 , '98 Hornet 600
| Visitor Q |
 Visitor Q $25 whore
| yen_powell |
| m0l0t0v |
 Posted: 19:23 - 15 Dec 2008 Post subject: |
| Visitor Q |
 Visitor Q $25 whore
| Visitor Q |
 Visitor Q $25 whore
| m0l0t0v |
 Posted: 20:36 - 15 Dec 2008 Post subject: |
| sickpup |
 sickpup Old Timer
| yen_powell |
| sickpup |
 sickpup Old Timer
| Visitor Q |
 Visitor Q $25 whore
| sickpup |
 sickpup Old Timer
| Visitor Q |
 Visitor Q $25 whore
| sickpup |
 sickpup Old Timer
| Visitor Q |
 Visitor Q $25 whore
| yen_powell |
| sickpup |
 sickpup Old Timer
| yen_powell |
| m0l0t0v |
 Posted: 00:35 - 17 Dec 2008 Post subject: |
| chillpill |
 chillpill World Chat Champion
 Posted: 13:28 - 17 Dec 2008 Post subject: |
dont know much about 4-stokes but im gona throw it out there anyway .......... valve clearances ? |
| Visitor Q |
 Visitor Q $25 whore
The last post was made 17 years, 308 days ago. Instead of replying here, would creating a new thread be more useful? |
