Fitting hot grips...quick answer needed...
PostPosted: 12:26 - 16 Dec 2008    Post subject: Fitting hot grips...quick answer needed... Reply with quote
When i took my old grips off,the throttle side has these high bits on it:
https://i187.photobucket.com/albums/x13/fronterapics/DSC00400.jpg
Am i supposed to grind these high bits off?
Th oxford grip wont fit the way it is...Do i need different grips to fit this bike?
There obviously there so the grip gets a better hold of the plastic of the rev thing,but if i take them off will the grip still hold to it?
Thanks
Dave
DRZ-400sm
virus
PostPosted: 12:31 - 16 Dec 2008    Post subject: Reply with quote
Just force the grip over it, a bit of hairspray (slippery when its wet, sticks when it dries) and a rubber mallet should sort it out.
John
own: 81 xs1100g...
Feasty
PostPosted: 12:33 - 16 Dec 2008    Post subject: Reply with quote
Couldn't say what to do about the 'high bits' however my Oxford grips are glued to the plastic rev thing so they don't slip... Thumbs Up
Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed). Also now a Tiger 1050, easily best of the lot!
yandy_yay
check the diameter before you cut the flanges off..
the oxford grips come with some superglue, but it's not very good quality so your better off buying some proper stuff the gel stuff is good for grips.
OR, see if you can get a different throttle assembly that will fit your bars.
Andy
past bikes: (20 years ago) cg-125 (wriiten off), C-50 (thrashed n' finnaly scrapped), CZ-125 (nicked - never recovered, insurance payout was more than i paid for it !!!)
Current bikes: GN 125(now sold), Divvy 600s.
PostPosted: 12:38 - 16 Dec 2008    Post subject: Reply with quote
Argh,i knew something woould go wrong..
I ground out a little bit of the plastic ring right at the end just i can get the grips started,but it feels quite a loose fit.
Theres no chance of the grips just pushing on the way it is with the high bits Confused
Why cant things just be easy. Crying or Very sad
DRZ-400sm
Odie
PostPosted: 13:55 - 16 Dec 2008    Post subject: Reply with quote
Ah you mean throttle, round where i live the chavs call it the rev, your not a chav are you? Shocked
odie
P.S
warm water if they are to small and as Virus said, hairspray, he should know!!! Mr. Green
Feasty
PostPosted: 14:05 - 16 Dec 2008    Post subject: Re: Fitting hot grips...quick answer needed... Reply with quote
justmetoo125 wrote:
There obviously there so the grip gets a better hold of the plastic of the rev thing...
Simply quoting the OP dear Odie, I myself am not a chav but if we all start calling the same parts different names it could get very confusing - therefore I decided to reply in the same manner the OP posted in, personally I call it the throttle or accelerator though. Wink
PostPosted: 14:11 - 16 Dec 2008    Post subject: Reply with quote
I had to grind all the bits off with the dremmell.
I left some a little proud so it was a tighter fit.It seems to be ok now i have the super-glue in it.
All done and fitted now anyway.
DRZ-400sm
ZaphodBeeble
PostPosted: 14:12 - 16 Dec 2008    Post subject: Reply with quote
Wire up the grips, turn them on and let them warm up. Should make them softer and easier to stretch. Smile
If I couldn't get them on the bars I would just cut the protruding bits off and use grip glue to be honest.
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
the grim reaper
PostPosted: 12:01 - 17 Dec 2008    Post subject: Reply with quote
I had exactly the same thnig on my old Bandit 1200. I ground the bits off and fitted the grips, then I bought a new plastic throttle slide off Ebay for £6, in case I wanted to re-fit the original grips.
Grim
The last post was made 17 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 65.34 Kb
