Kmx 125 wont start, please help
sam_w
PostPosted: 13:40 - 16 Dec 2008    Post subject: Kmx 125 wont start, please help Reply with quote
i tried to start it this morning and i couldnt even get it to tick over. i tried it on the choke and everything. it was quite hard to start when i used it last saturday but it was at least ticking over and then cutting out, now it wont even tick over. Anyone any suggestions to what the problem is? before sarurday it would fire up on the first kick
Edit: one more thing i forgot to mention. i heard a pop/backfire in the exhaust on a couple of kicks this morning but this didnt happen on every kick
Keir
PostPosted: 13:50 - 16 Dec 2008    Post subject: Reply with quote
new spark plug required possibly.
Current : '08 Yamaha FZ1s
sam_w
PostPosted: 14:01 - 16 Dec 2008    Post subject: Reply with quote
yer i was thinkin it might be spark plug related as it was startin up fine up until a few days ago. thanks for the quick reply mate
Keir
PostPosted: 15:44 - 16 Dec 2008    Post subject: Reply with quote
when was the last rebuild? If its not the plug being fouled then a compression test would be the next thing i would do.
sam_w
PostPosted: 18:19 - 16 Dec 2008    Post subject: Reply with quote
it hasnt had a re-bulid yet. its only done 9000 miles. Wouldnt there be other signs of needing a re-build like loss of power etc? the bike has been runing great up until the last two times ive used it so i dont think its that. i think its plug related. il take the plug out and check its condition and replace. thanks
sam_w
PostPosted: 18:20 - 16 Dec 2008    Post subject: Reply with quote
if my plug is fouled does that just mean my mixture just needs a bit tuning?
Jello
PostPosted: 20:43 - 16 Dec 2008    Post subject: Reply with quote
Not necessarily.
Try a new plug and see what happens. What condition was the plug in when you took it out?
Honda MTX 125
chillpill
PostPosted: 13:22 - 17 Dec 2008    Post subject: Reply with quote
combination of cold conditions , bad plug and needing new rings
fit new piston rings as soon as you can mate before it starts marking the barrel Wink Thumbs Up
Keir
PostPosted: 14:13 - 17 Dec 2008    Post subject: Reply with quote
i wouldnt start messing with the mixture if its been fine for 9k. just stick in a new plug. As chill says, after 9k you could do with new rings and might aswell do the piston while you're there - they are maintenance items on a 2t.
sam_w
PostPosted: 15:29 - 17 Dec 2008    Post subject: Reply with quote
ok thanks for your help guys. just an update i took the plug out and it was a little black but not oil fouled. i put the plug back in and the bike started 1st kick but was bogging down when i tried to give it a bit of throttle then just cut out. so any idea what problem this might indicate? i will also replace the piston and rings like suggested
chillpill
PostPosted: 15:50 - 17 Dec 2008    Post subject: Reply with quote
indicates low compression , wich would be fixed by piston and rings Wink dont forget a new gaskets to go with your piston Thumbs Up
stevo as b4
PostPosted: 23:46 - 17 Dec 2008    Post subject: Reply with quote
my 200 just poped and backfired a couple of times when i tried kicking it over, after the engine made some nasty noises and ground to a halt. The reason for this was that the piston crown and rings had come away from the skirt, and i had a bottom end and exhaust full of bits of metal, and sod all compression.
I doubt that is your bike's problem, but it's certainely worth checking the compression pressure which should for the 125 be between 120-178psi.
The last post was made 17 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 70.52 Kb
