De-restricting my Jicheng Easy Rider 125
mm08is
PostPosted: 13:57 - 18 Dec 2008    Post subject: De-restricting my Jicheng Easy Rider 125 Reply with quote
Hi all, just bought a 125cc bike, need to commute to work and back and its abit slow, anyone know how to increase the top speed and/or acceleration?
thanks
Jamie S
PostPosted: 14:11 - 18 Dec 2008    Post subject: Reply with quote
They are not restricted in the first place, if you want a faster bike get a 2 stroke.
PostPosted: 15:26 - 18 Dec 2008    Post subject: Re: De-restricting my Jicheng Easy Rider 125 Reply with quote
thanks
The clue's in the name. Jicheng Easy Rider. Says it all really.
First off, its clearly chinese and so isn't going to be super quick or well built. Second of all, its called 'easy rider' so its bound to be a cruiser.
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Thom
PostPosted: 15:43 - 18 Dec 2008    Post subject: Reply with quote
a) Use the search function
b) It's never going to be a quick bike
c) Can we add the word "De-restricting" to a profanity filter? Razz
cammy mack
PostPosted: 17:19 - 18 Dec 2008    Post subject: Reply with quote
try changing the sprockets IF you can get spares for it.
Yamaha Tdm850
Yamaha fz6
Gawain
PostPosted: 18:14 - 18 Dec 2008    Post subject: Reply with quote
Its not restricted its just slow. Gaining performance is usual 4T stuff, exhaust, larger carb. Gearing changes can give you slightly more top speed or faster acceleration, not both
metal ken
PostPosted: 18:56 - 18 Dec 2008    Post subject: Reply with quote
No offence, but a lot of chineese bikes are not as good quality and getting more power out of it might damage parts, and there is not too many performance products for these kind of bike.
I would try to find out if the bike is a copy of a Jap bike and see if any performance jap parts are compatable
But on the other hand if you wanted to give it a bit of power you could port the exhaust outlet so it is nice and smooth, take off the cast marks of the inket port and carb, but leave it a bit rough for air feul turbulance, make sure the throttle opens fully, see if you can get a high flow air filter, definatly make sure you have the right tyre pressures and the wheels move freely, and as robert mack said try changing the sprocket ratio, put a high flow feul filter on it, there are other things you can do aswel, but this might give you a few more horses and a smoother ride.
Good luck, Ken Thumbs Up
My motorbike breakers metalken.co.uk
Current bikes, GSXR750 Fighter, GSXR7/12, RD350 race rep, KH400
keymeister
PostPosted: 22:03 - 18 Dec 2008    Post subject: Reply with quote
Hi mate
It is not restricted there are some emissions shite which should have been removed by the importer I have a monkey bike made by them (and also a triumph sprint and an R1) replace anything that wears out with Honda parts, the brake pads before you ride it and change the oil at 2k intervals if you want speed then pass your test a restricted cbr 6 , will do 80mph 2 up
keymeister
Hi mate
PostPosted: 01:48 - 19 Dec 2008    Post subject: Re: De-restricting my Jicheng Easy Rider 125 Reply with quote
Think Easy Rider is the name used by my local bike shop (CG Chells) for the Chinese bikes they have been bringing in for years.
tribal_tiger
PostPosted: 07:52 - 19 Dec 2008    Post subject: Reply with quote
I had a chinese CG clone. Tried everything to make that bugger go faster.
The best thing I found was going on a diet. Thumbs Up Mr. Green Thumbs Up
How much wood would a woodchuck chuck if a woodchuck could Chuck Norris?
All of it.
Smooth
PostPosted: 09:24 - 19 Dec 2008    Post subject: Reply with quote
metal ken wrote:
.....on the other hand if you wanted to give it a bit of power you could port the exhaust outlet so it is nice and smooth, take off the cast marks of the inket port and carb, but leave it a bit rough for air feul turbulance, make sure the throttle opens fully, see if you can get a high flow air filter, definatly make sure you have the right tyre pressures and the wheels move freely, and as robert mack said try changing the sprocket ratio, put a high flow feul filter on it, there are other things you can do aswel, but this might give you a few more horses and a smoother ride.
I agree with the above. Spending time to set up the bike as per design spec can make a big difference for almost zero cost and only a few hours fettling.
Improving the airflow is taking it a step further. Depending upon whether it runs rich as standard, the carb may need re-jetting to compensate.
TDM850
PostPosted: 15:23 - 19 Dec 2008    Post subject: Reply with quote
My old chinese bike would rev out in top gear at about 45mph*
I changed the sprockets and chain,which got it to about 65-70mph*.
(*indicated speed)
DRZ-400sm
stirlinggaz
PostPosted: 21:49 - 19 Dec 2008    Post subject: Reply with quote
hi,
its all been said before but...
the chinese cg clones which i have owned are usually good for an indicated 80mph, (more like just over 70).
mikuni 29mm carb & conical airfilter usually unleashes what little more power they have.
change sprockets to suit.
the guys over on the chinese bike forum can advise on other upgrades such as exhausts(hard to match one up) & bbk's.
best ran with a decent spark plug (ditch the dodgy torch or lg one, they are prone to serious failure)
brakes & other parts arnt up to those speeds though, so do frequent oil changes, fit decent brake pads & use plenty of threadtite, cos you'll lose plenty of bits! lol.
cheers,
GAZ
The last post was made 17 years, 30 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 82.18 Kb
