GPZ 500 (D1 '97) front axle bolt
Purplepill
PostPosted: 16:17 - 18 Dec 2008    Post subject: GPZ 500 (D1 '97) front axle bolt Reply with quote
Does anyone know what size allen key I need to undo the front axle nut on my bike, my biggest is 10mm so im guessing its around 14mm but want to make sure so I dont buy the wrong size, I dont have any bolts I can use to compare either.... cheers
''He had the confidence of a baby-goat dared to tickle a t-rex's nutsack''
PostPosted: 17:14 - 18 Dec 2008    Post subject: Reply with quote
You can use a long bolt with a 90 degree bend in it instead of an allen key too. Use the head of the bolt to go into the spindle and the shaft as a handle.
It was either 13mm or 14mm, you could measure it with a ruler.
EDIT: Or measure it up against the open end of a 13 and 14mm spanner.
Purplepill
PostPosted: 00:49 - 19 Dec 2008    Post subject: Reply with quote
Cheers stinkwheel, tryed measuring it but it had a sort of bevelled edge which made it hard to be certain, also my measuring skills suck Embarassed sorted it in the end though, turned out to be 12mm.
The last post was made 17 years, 317 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 3.49 - MySQL Queries: 13 - Page Size: 35.6 Kb
