Replaced my sprag, now won't start...
loply
PostPosted: 10:24 - 19 Dec 2008    Post subject: Replaced my sprag, now won't start... Reply with quote
Hi folks!
I replaced the "sprag clutch" (one-way bearing starter clutch thing, connects starter motor to flywheel) on my Aprilia RSV and I'm having difficulties. The old sprag had worn out meaning the starter motor would spin without connecting to the engine.
I got a brand new one, popped the flywheel off etc, fitted it.
Reassembled and hit the starter button, the motor sounds like it's turning over but it doesn't turn consistently fast... It sounds like the speed of the starter motor is fluctuating up and down and never reaching full pelt. About half a second of decent motion, then it "stalls" (goes quiet and slows down) and starts again.
Basically it sounds like a flat battery but the starter goes up and down rather than consistent speed.
This is a brand new fancy pants Varta battery that was fine beforehand, and has been in my house on an optimate for a week. To be sure, I also used another battery from another bike (also 100% fine) and that was the same.
I stripped the whole thing (with much swearing!) and can't see any evidence of a problem, the sprag is still fine, no metal shards, it locks fine etc.
The only suspicious thing I did notice was that, despite using loctite 648 and torquing to 120NM with the crankshaft locked, the flywheel had 1-2mm of freeplay back and forth on the crankshaft?
Any suggestions what to double check?
Yamaha SZR660 Caution to the wind, the throttle pinned!
PostPosted: 14:40 - 19 Dec 2008    Post subject: Reply with quote
Can you bump it?
To be fair the reason why it sounds like it's "flucuating" is probably because it's pushing those two big pistons over their compression strokes(Mille's are very hard on the starting system as you know). Mine used to sound like that before it caught.
I'd be surprised but have you tripped the tilt switch?
loply
PostPosted: 17:15 - 19 Dec 2008    Post subject: Reply with quote
I've not owned the bike for long but I can say for sure it's not the normal sound of the started, if you heard it you'd instantly agree.
I checked the kill switch but not the tip switch, bike hasn't been horizontal or anything though.
PostPosted: 09:15 - 20 Dec 2008    Post subject: Reply with quote
Yeah I agree, but sometimes the switch can just fail.... If you can bump it at least you know it's the starting system as oppose to anything more sinister. Thumbs Up
NiteMare
PostPosted: 10:42 - 20 Dec 2008    Post subject: Reply with quote
Quote...
Endquote
i'd definitely get that freeplay sorted before even considering firing the engine up, a flywheel that moves will eat the end off the crank ...
have you forgotten to replace a shim ??
it ain't broke...
i ain't fixed it enough
The last post was made 17 years, 31 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 45.25 Kb
