 ---- World Chat Champion
 Posted: 20:11 - 20 Dec 2008 Post subject: Best way to remove hot grips? |
It's the throttle side one i just cant get back off.I stupidly glued it on without checking it was in the right place so now it's awkward to get to the starter button.
Dave ____________________ DRZ-400sm |
| Itchy |
 Itchy Super Spammer
 Posted: 20:13 - 20 Dec 2008 Post subject: |
And they sealed at the bar ends? or do they cover the bar ends too?
If they are open ended screw driver under neath and around should come off easy, I just ripped them straight off the AT. Might want to spray in some WD40 too
if they are covering the ends screw driver but carefully on the inner side slowly teasing it off. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
 Posted: 20:18 - 20 Dec 2008 Post subject: |
The grips have a hard plastic tube in the middle,which then glue to the plastic throttle tube,so i couldn't get a screwdriver in without snapping the plastic.
Same reason i cant get wd40 into it.
I was thinking i could put the whole throttle tube with grip into some hot water to try weaken the glue?
Would this fvck the grips? ____________________ DRZ-400sm |
| alun111 |
 alun111 World Chat Champion
The last post was made 17 years, 47 days ago. Instead of replying here, would creating a new thread be more useful? |
