| LanaTheGreat |
 LanaTheGreat Scooby Slapper
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 21:50 - 20 Dec 2008 Post subject: |
shit they speak... they're trying to get more money.
change the small end bearing for about £3 for the part.
if you show them this thread they'll say something like ''well its better to be safe'' or something.
get it done when it needs to be done. big end bearings are pretty gradual, and pretty obvious.
also, a new crankshaft is probably more cost effective when it decides to go. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 21:55 - 20 Dec 2008 Post subject: |
to get the crankand pin out you need to slit the cases, then use a press to remove the pin,
so yep,
but you dont normally need to do that every time you replace a piston,
grab the top of the conrod and move it side to side,
it should only slide but not move too much pivioting from the crank pin,
also rotate the crank and see if you can feel any grinding on the bearing through the conrod,
if you can feel any at all, then you will have to replace the conrod,bearing and crank pin,
good luck  ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| Kickstart |
 Kickstart The Oracle
| LanaTheGreat |
| Ariel Badger |
 Ariel Badger Super Spammer
The last post was made 17 years, 48 days ago. Instead of replying here, would creating a new thread be more useful? |
