2 stroke exhaust
armedpitbull
PostPosted: 18:47 - 21 Dec 2008    Post subject: 2 stroke exhaust Reply with quote
how long can the exhast be (after chamber) before affecting performance?
how can i write my signature when my pen wont write on the screen??
veze
PostPosted: 20:36 - 21 Dec 2008    Post subject: Reply with quote
are you thinking of making one up then? what bikes it for?
tlm50,mt5,sr50. rs125 extrema, cbr 400rr nc29 suzuki gs500e.Honda cbx250 rs . FJ1200 .fz6,fjr1300
armedpitbull
PostPosted: 21:27 - 21 Dec 2008    Post subject: Reply with quote
im converting rs 125 to under seat exhaust, so it would mean lenghting the pipe between the chamber and can.
MaybeGuy
PostPosted: 21:35 - 21 Dec 2008    Post subject: Reply with quote
a GPR125 has an underseat exhaust, and pretty much the same engine.
would probably be easier and better to modify one of them to fit.
stevo as b4
PostPosted: 21:46 - 21 Dec 2008    Post subject: Reply with quote
Keep the diameter of the stinger (pipe from expansion chamber to silencer) the same as it is now, and i doub't the performance will be affected in any noticable way. Diameter is far more important than length, and next is the severity of the bends. This point is not directly due to how it affects the pressure waves, but if you had two or more 90deg tight bends, then it would start to act more like a silencer baffle with a possible restriction to flow.
If the route to the silencer is very long, then id consider going up slightly in size after the exit from the chamber. Say a 2mm increase in bore size for a long run would be enough to ensure performance is not handicapped. Lots of 2stroke bikes have long pipes from the expansion chamber to the silencer, (Most trail/enduro/MX bikes for a start.
armedpitbull
PostPosted: 21:52 - 21 Dec 2008    Post subject: Reply with quote
thanks for your help. will post pics when done Very Happy
The last post was made 17 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 47.45 Kb
