derbi senda metrakit sp 70cc big bore kit
benjy bwoii
PostPosted: 20:40 - 18 Dec 2008    Post subject: derbi senda metrakit sp 70cc big bore kit Reply with quote
hello i was thinking about buying a metrakit sp 70cc big bore kit and i was wondering are they reliable kit and what sort of bhp could i reach my set up at the moment is leo vince v6 race pipe mallosi 21mm carb.thanks everyone.
Hutchysrs50
PostPosted: 18:38 - 21 Dec 2008    Post subject: Reply with quote
the bikes are somthing like 2.3bhp standard.
no they are not reliable, but mostly comes down to how you ride them, your going to be riding it in the red if your putting a bigbore kit on, so your crank or brearings are going to be under alot more stress, also without the correct setup, they usualy seize befor anything els...
top speed will go up by about 4mph too Thumbs Up
Gilera SC 125 - Current
PostPosted: 20:36 - 21 Dec 2008    Post subject: Reply with quote
If he's riding in the red, can he not change gear Confused
It'll only seize if he runs it without any oil or runs it super lean.
Also, his top speed won't go up at all unless he changes his final gear ratio.
Hutchysrs50
PostPosted: 20:41 - 21 Dec 2008    Post subject: Reply with quote
"If he's riding in the red, can he not change gear"
not sure what you mean by that?
"It'll only seize if he runs it without any oil or runs it super lean"
even tho the oil pump only puts out enough to run 50cc not 70cc?
"Also, his top speed won't go up at all unless he changes his final gear ratio"
it will go up as it will rev higher, with the 50cc head on they are ment to rev to 12k but with the big bore kits they rev to 15k
so more rpm = higher top speed?
stevo as b4
PostPosted: 23:02 - 21 Dec 2008    Post subject: Reply with quote
The MetraKit SP isn't a race kit, just a fast road 70cc kit, so i don't expect it to be ported much different to std, or rev past 12K or whatever the current limit is. The Cdi might well have an electronic limiter anyway. As said the only way for top speed to increase is to install new sprockets. If you get it right you should get a few mph more and better acceleration.
The Oil pump should supply enough oil for a 70cc top end, as none of the manufacturers normally state that a new pump is needed. It might be worth adjusting it slightly to provide more oil before full throttle is reached though. The rad is a decent size for the bike IMO so the cooling system should cope ok too.
TBH i wouldn't buy a big bore kit unless you can have these issues confirmed for certain by the manufacturer, as any reputable tuning company would make sure everything works and is up to the job before they start selling kits.
Reliability should be ok, but more cc will cause more wear on the bottom end, and so re-builds should be carried out more frequently than the std bike, and in line with what the aftermarket tuners reccomend.
Think the Derbi is about 8bhp std, so a well set up 70cc kit with the bigger carb and performance pipe you have should be getting close to 12bhp id say.
Hutchysrs50
PostPosted: 00:01 - 22 Dec 2008    Post subject: Reply with quote
2.41 BHP (1.8 kW)) @ 6500 RPM - Stock Thumbs Up
benjy bwoii
PostPosted: 01:36 - 22 Dec 2008    Post subject: Reply with quote
cheerz people im reaching about 65 now soo what top end will ill be seeign with the right sprocket set up.cheerz.
benjy bwoii
PostPosted: 01:39 - 22 Dec 2008    Post subject: Reply with quote
and also is it true you can get top speed pipes e.g ginelli and tecknogas is this true as i have been told a leo vince is a bottom end/mid rang race pipe.cheerz.
PostPosted: 01:58 - 22 Dec 2008    Post subject: Reply with quote
If he's in the red part of the rev counter, change up.
Also, the big bore kit will rev no more than the normal, the rev limiter doesn't change Rolling Eyes
Hutchysrs50
PostPosted: 13:55 - 22 Dec 2008    Post subject: Reply with quote
a quote from a few websites that sell these kits.
'An ideally replacement cylinder kit with a little higher rev as the original one'
im sure upjetting the carb, uprating the oil, and having a bigging cylinder will make it rev higher?
Here is a super clear video Embarassed to show what i mean about riding past the red and the revs being higher.
https://uk.youtube.com/watch?v=zmP0BnXLqjo&NR=1
Finglonga
PostPosted: 14:38 - 22 Dec 2008    Post subject: Reply with quote
May rev slightly higher but the crank won't last long.
Andy Sez....
F.Y.Y.F.F.
PostPosted: 15:02 - 22 Dec 2008    Post subject: Reply with quote
Truslack used to rev his RS50 past the redline until it hit the rev limiter.
If you can hit the rev limiter with a 50cc piston and barrel it won't change when you fit a 70cc, it might just get there quicker.
EnergyInducti...
PostPosted: 15:10 - 22 Dec 2008    Post subject: Reply with quote
Basically, what your saying is, Even if the kit has a higher rev capability, Nothing will change top speed wise, Because it will stop at the same RPM, With the SAME gear ratio, Producing the EXACT same top speed as before... Therefor, If you wanna go faster, Get a free revving CDI (Dangerous) or get a smaller front sprocket/Bigger rear sprocket
Am I right? =/
I was just attempting to simplify the matter... If I got it wrong, please tell me
Riding: Yamaha RXS100
Aiming for : RD350 + Test
Dream bike: Suzi RG500 Gamma
Hutchysrs50
If he's in the red part of the rev counter, change up. Laughing
sorry couldnt resist, to be fair, i ride my tzr 50 past the redline at times, but from what your saying Embarassed a 50cc bike will rev the same as a 14,000cc bike? i dont know, they might do?
EnergyInducti...
PostPosted: 15:14 - 22 Dec 2008    Post subject: Reply with quote
I would love a 14litre engine, Where can I get one? Laughing Sorry, I couldnt resist, nothing personal there, Sorry.
Hutchysrs50
PostPosted: 15:25 - 22 Dec 2008    Post subject: Reply with quote
non taken Rolling Eyes
get a Zx14 Surprised
EnergyInducti...
PostPosted: 15:27 - 22 Dec 2008    Post subject: Reply with quote
I'll stick to 50/70cc's thanks ^.^ Its where I belong...
Scooter tuning is more fun than it sounds
PostPosted: 15:31 - 22 Dec 2008    Post subject: Reply with quote
Am I right? =/
That's correct, apart from it's bigger front sprocket/smaller rear sprocket to increase top speed Wink
What the hell are you going on about now?
What has a 14 litre engine got to do with you saying a 70cc will rev higher than a 50cc?
benjy bwoii
PostPosted: 16:19 - 27 Dec 2008    Post subject: Reply with quote
hello people why does my bike sort of start shutting down at like 8 and a half thousand revs and wont rev in to the red bit and all of my m8s derbi senda do it.cheerz.
chillpill
PostPosted: 18:12 - 27 Dec 2008    Post subject: Reply with quote
upjet
chillpill
PostPosted: 18:19 - 27 Dec 2008    Post subject: Reply with quote
not quite , you need a expansion chamber to match the power of your barell , if the cylinder is ported to make all its power 1t 8-11k and the exhaust makes low down power its going to be shit
i dont have a clue about derbi senda bits , try a derbi forum for more info on tuning
benjy bwoii
PostPosted: 19:36 - 27 Dec 2008    Post subject: Reply with quote
cheerz people and i have a leo vince v6 pipe and a malossi 21mm carb and im thinking bout a metrakit sp 70cc kit could i reach 15 bhp if set up properlyy.chherz and what top speed would i be looking at if geared properlyy.cheerz.
The last post was made 17 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.63 Sec - Server Load: 2.97 - MySQL Queries: 13 - Page Size: 119.58 Kb
