Lights
TJ NSR
PostPosted: 17:41 - 02 Mar 2002    Post subject: Lights Reply with quote
hi every1,
got a problem
ive got a 2001 nsr when i turn the dipped beam on only the left light turns on.
is this standard????
when high beam is on they both turn on
is there a way of sorting this?? as its annoying, and ive seen bare nsrs with twin beam.
thanks guys and girls for any help
safe riding...
Vissie
PostPosted: 17:45 - 02 Mar 2002    Post subject: Reply with quote
It is normal check out almost all the new bikes do it. Ducati, Yamaha...
It is normal Smile
TJ NSR
PostPosted: 17:49 - 02 Mar 2002    Post subject: new bikes ye Reply with quote
but there must be a way of making twin beam, ive seen other nsrs with twin beams.
any one got ne suggestions
Guest
PostPosted: 18:27 - 02 Mar 2002    Post subject: Reply with quote
You propablyneed to replace the light bulb on the right. Samething happened to me. There is two curcuits inside the bulb, which means that the high beam can work even if theother one is broken.
Milo
PostPosted: 19:35 - 02 Mar 2002    Post subject: Reply with quote
You sure you're talking about dipped beam?
on mine and my mate's new NSR's on the first setting only 1 of the smaller bulbs came on. dipped beam both main bulbs were on. high bea and both were on high. another mate's 2nd hand NSR had both smaller lights on when side lights were on. there's no problem with the bike-it just depends on who built it. most bikes just have the 1 bulb on but it doesn'#t matter either way. during the day just use the sidelights, never full beam. sidelights help with the visibility problem but it doesn't create a beam. using dipped beam during the day can be hazardous, if you hit even a small bump a car waiting to pull out could take it as a flash, so they pull out in front of you-beware!
Shaft drives rule. Razz
tanner
Guest
PostPosted: 23:15 - 02 Mar 2002    Post subject: bulbs Reply with quote
just change the bulbs nsr s have twin head lights mine is a 2000 model but i had the same thing happen to me soon ya high beam will fuck up like mine did and my green side light where clearly visible bulbs only cost £2.70 what ya waiting for i would change both bulbs to 35 watt bulbs there alot brighter 8)
TJ NSR
PostPosted: 23:21 - 02 Mar 2002    Post subject: bulbs Reply with quote
thanks guys ill change the bulbs wats the best way of doing it???
Dylan
PostPosted: 18:36 - 03 Mar 2002    Post subject: Reply with quote
With a lot of damn trouble. I wont recomend any way because i got a differant model, and last time i changed the bulb i smashed it and shards of glass in my hand!!!! Crying or Very sad Good luck
Dyl
STUMP
Guest
PostPosted: 11:18 - 04 Mar 2002    Post subject: lights Reply with quote
Dont bother buying a new bulb yet!
Sometimes the connection gets a bit loose are gits a bit od grit on it.
Just take out the bulb clean both parts where it connects and ya should be fine.
crash
PostPosted: 13:35 - 04 Mar 2002    Post subject: lights Reply with quote
get ure circets checked, then fit 40, 45 there brillent for night time racing round back roads u can get them from a local bike shop or m and p, fitting tham was a bollox cuz i hav biggish hands so a girl friend would come in handy, with close supervision of course.....
TJ NSR
PostPosted: 19:20 - 05 Mar 2002    Post subject: thanks Reply with quote
Thanks guys have a nice week!!!
The last post was made 23 years, 294 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 61.85 Kb
