Backing it in.
Irezumi aka Reuben
Carrot Top
PostPosted: 18:09 - 24 Dec 2008    Post subject: Backing it in. Reply with quote
OK, as I have a motard I have decided it's good fun to try and back it in/slide about. Apart from the drive chain/clutch/tyres what accelerated damage is possible?
Finglonga
PostPosted: 18:21 - 24 Dec 2008    Post subject: Reply with quote
Falling off, that's about it. Wink
Andy Sez....
F.Y.Y.F.F.
MattHirst
PostPosted: 18:45 - 24 Dec 2008    Post subject: Reply with quote
The toesliders on your boots Very Happy
If you do it right you won't really damage the chain. But if you get it wrong and it ends up being really jerky and 'snaps' back into line after the corner then it will put excessive wear and strain on the chain.
The clutch shouldn't really be affected as you aren't using the clutch to back it in. What you are doing is making the rear wheel spin at a slower speed to the road speed.
Edit - i'm a numpty and made loads of typos Razz
sickpup
Old Timer
PostPosted: 20:43 - 24 Dec 2008    Post subject: Reply with quote
Being shown up by couriers on scooters doing it better than you. Wink
Blue_SV650S
PostPosted: 21:42 - 24 Dec 2008    Post subject: Reply with quote
Sadly for those of us that are NOT blessed with slipper clutches ... slipping the clutch is exactly what you need to do!! Razz
Anyway, like with the chain that doesn't get much hard if you do it right, it is the same for the rear shock ... if you are juddering things or near highsiding it a lot, then the shock gets a real work out ...
Irezumi aka Reuben
Carrot Top
PostPosted: 00:29 - 25 Dec 2008    Post subject: Reply with quote
I'm not making the bike judder as I am slipping the clutch, I've also unloaded the rear completely. I was just curious as to what engine wear would be caused by this.
I manage to stay upright most of the time though. The couriers I know have had more accidents than me! Laughing
Blue_SV650S
PostPosted: 00:33 - 25 Dec 2008    Post subject: Reply with quote
is it a 2-smoke?
Especially if it is pre-mix, high revvs 'overrun' is what makes them go pop ... i.e. lots of revvs, not much fuel/oil flow!! Shocked
If it is a 4-stroke, then I can't see it causing any real abnormal problems.
Irezumi aka Reuben
Carrot Top
PostPosted: 00:58 - 25 Dec 2008    Post subject: Reply with quote
Yes, it's a 4-stroke, fairly sure that due to lack of engine braking locking up the rear would be quite difficult (is it impossible?) on a 2-stroke.
I was considering possible excessive pressure on con-rod bearings/big ends etc...
Faraz
PostPosted: 02:41 - 25 Dec 2008    Post subject: Reply with quote
Your wallet.
'56 Yamaha MT-01
'05 Nissan 350z Roadster GT
3 words dude.. Fvck. Yes.
The last post was made 17 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.78 - MySQL Queries: 13 - Page Size: 60.05 Kb
