| The Artist |
 The Artist Super Spammer
| 5v3d3b0 |
 5v3d3b0 World Chat Champion
| The Artist |
| ms51ves3 |
 ms51ves3 Super Spammer
| Ichy |
 Ichy World Chat Champion
 Posted: 10:26 - 25 Dec 2008 Post subject: |
Have a quick read of this before you do anything else. You might have a bit more luck.
The pilot, controls the mixture at closed throttle, when the bike is ticking over. It can be adjusted by manipulating two parts: the air screw and the pilot jet. The air screw controls the flow of air into the circuit. Turning the air screw clockwise reduces the air flow and richens the circuit. Turning it counter clockwise increases the airflow and leans the circuit. You can therefore use the air screw to fine tune the pilot circuit. The pilot jet restricts/regulates the flow of petrol from the float bowl to the venturi. Pilot jets have a precisely machined orifice/hole running through their center which petrol passes through. Increasing the size of the pilot jet ( size of the hole ) richens the circuit by supplying more petrol; i.e. removing a 40 pilot jet and installing a 42 richens the circuit. Sometimes the mixture screw will control the fuel flow at idle. Fairly obvious if it does and it just means the screw has the opposite effect.
The jet needle – Has the greatest effect between 1/4 and 3/4 throttle. It’s attached directly to the throttle valve. As the throttle is rolled open or closed the jet needle moves through the needle jet’s bore exposing different sections of the jet needle’s profile to the needle jet’s inner bore.
Six major elements determine the jet needle’s effect on fuel delivery - the diameter of the straight section, the length of the straight section, the jet needle’s taper, the clip position, the number of tapers and the length of each tapered section. The number of tapers is normally not changed from what was supplied from the factory. Only real adjustment you can have on the needle is the clip position although not all needles allow you to move the clip. Small washers placed under the clip work just as well. I've never need to drop a needle.
The Main Jet- regulates the flow of petrol from ¾ to Wide Open Throttle. Like the pilot jet the main jet has a precisely sized hole drilled through its center. Increasing the size of the main jet ( size of the hole ) richens the circuit by supplying more gasoline; i.e. removing a 72 main jet and installing a 90 richens the circuit.
Put simply, the pilot (mixture screw) controls the fuel at zero to partially open. The Needle works for 1/4 -3/4 throttle and the main jet is full throttle. Its not this simple because of overlap but what it does mean is that the mixture screw has very little effect on the full throttle.
Usually you would tune a carb working from the top down. Main, needle then pilot.
If I was you I would put it all back to standard then do a plug chop at full throttle for a few miles. If the plug looks good then the main is fine. Next same at 1/2 to 3/4 to check the needle. Finally once its warmed up let it sit of 10 minutes on idle to check the pilot. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| The Artist |
| adamcpi50sx08 |
 adamcpi50sx08 Renault 5 Driver
| The Artist |
| Ichy |
The last post was made 17 years, 296 days ago. Instead of replying here, would creating a new thread be more useful? |
