| calum17 |
 calum17 Brolly Dolly
| yandy_yay |
 yandy_yay Brolly Dolly
| calum17 |
| stirlinggaz |
| calum17 |
| stirlinggaz |
| metal ken |
 metal ken Spanner Monkey
 Posted: 21:41 - 26 Dec 2008 Post subject: |
when i installed power sockets to BMW bikes, I done the same with the masking tape, and drilled a small hole then used a tapered drill bit to get the hole to the correct size.
Ken  ____________________ My motorbike breakers metalken.co.uk
Current bikes, GSXR750 Fighter, GSXR7/12, RD350 race rep, KH400 |
| ajb |
 ajb Crazy Courier
 Posted: 21:53 - 26 Dec 2008 Post subject: |
you may find it easier with wood bits, as they have a small point which stops the bit 'walking' across the surface and stratchng it.
Once you have a pilot hole, any wood/HSS bit will do, prefereably the sharper the better, but as said, let the bit to the work, you won't need much pressure. A piece of wood under neath will help to rest onto lightly (will also minimise the back of the plastic fraying out)
You may also find a stanley knife / rat tail file useful for tidying it after if the hole isn't clean.
PS. Tip, always favour a smaller hole (lol) to start with, and when you get close, try offering up the bit you are fixing, because once you make the hole too big, there is no going back  ____________________ CBR125R '05 > CB500 '00 > CBR600F '99 |
 Posted: 22:09 - 26 Dec 2008 Post subject: |
Make a small pilot hole, of 1/3 the finished size, then drill it with your finished-size drill. For plastic I use a new bit and run my battery-drill at top speed with very light pressure. ____________________ a.k.a 'Geri'
| iooi |
 iooi Super Spammer
| calum17 |
| Ichy |
 Ichy World Chat Champion
| calum17 |
The last post was made 17 years, 276 days ago. Instead of replying here, would creating a new thread be more useful? |
