Crank the throttle and the engine dies ??
JohnyBigPotat...
PostPosted: 13:50 - 29 Dec 2008    Post subject: Crank the throttle and the engine dies ?? Reply with quote
Ok so I have an old 1983 Honda CL250, she starts up and ticks over lovely - but when you crank the throttle open and give her a bit of sharp revs the engine dies? and I have no idea why this would happen?
Cheers in advance for any responses
Ariel Badger
PostPosted: 14:00 - 29 Dec 2008    Post subject: Reply with quote
Carb(s) off and clean them. She is getting nothing through the main jet.
JohnyBigPotat...
PostPosted: 14:32 - 29 Dec 2008    Post subject: Reply with quote
Any particular way you would recomend to clean them out?
smegballs
PostPosted: 14:51 - 29 Dec 2008    Post subject: Reply with quote
Petrol for general carb cleaning. If you really wanna splah out you can buy "carb cleaner" from most auto shops.
Watch out tho because some rubber seals and gaskets etc really dont get on with carb cleaner, so remove as a precaution.
What you must never do tho is "clean" jets by poking stuff up them!!
The brass jets are precision machined and poking stuff (wire) up them will enlarge them, thus changing your carbs jetting.
Best way to clean them is blow through all the jets and air passages with an airline from a compressor.
Failing this, the end of a bicycle pump adaptor over the jet and a quick pump will work as well.
Happy cleaning,
Rich
PS, if you have a slide carb make sure you put the slide back in the right way round!!
Timmeh
PostPosted: 23:21 - 29 Dec 2008    Post subject: Reply with quote
That, and if the bike's been stood for a while it might also be degraded fuel or a bit of water in the tank.
The last post was made 17 years, 282 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.38 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 42.86 Kb
