| The Disapproving Brit |
 The Disapproving Brit World Chat Champion
| rotax81 |
 rotax81 Nearly there...
| loply |
 loply World Chat Champion
 Posted: 17:02 - 29 Dec 2008 Post subject: |
If it's consistently dying every few days I would say that is definately abnormal.
You need to verify the current being drawn by the alarm. Do you have an electrical multimeter? If not, they are only £10-£20.
Set it to DC Amps, sometimes labeled DCA, and disconnect your positive battery lead whilst the engine is off. At this point the alarm will probably go off.
Then put one lead of the multimeter on the positive battery terminal, and the other onto the lead you just disconnected.
The multimeter will now tell you how much current is being drawn, I don't know how much alarms are meant to draw but a normal bike with a clock etc would only suck <10mA. For a fairly hefty 12ah battery if the alarm was sucking 500ma the battery would be dead in 24 hours. Similarly, 250ma would kill the battery in 48 hours.
If the alarm is not killing the battery, it may be that it is not being charged by your bikes charging system.
Again use the multimeter to test this. Put it in DC Volts mode and put the two probes on the two terminals of the battery. It should be something like 12.8v. Then turn the engine on, it should jump up to about 13.5. Rev the engine up to about 5k and keep it there , the voltage should go up some more. Note to do this with the lights off.
If it doesnt, this would seem to indicate your bike isnt recharging the battery - could be a faulty reg/rec or various other things. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| The Artist |
 The Artist Super Spammer
| joop200789 |
 joop200789 Renault 5 Driver
| loply |
| joop200789 |
| Walloper |
 Walloper Super Spammer
| Ariel Badger |
 Ariel Badger Super Spammer
| iooi |
 iooi Super Spammer
| Timmeh |
 Timmeh World Chat Champion
 Posted: 10:29 - 30 Dec 2008 Post subject: |
Thanks guys.
Point about some people having sigs turned off duly noted Yes, it's a '2000 Kymco Zing. Unfortunately, I've not really had it long enough to know what's 'normal' (I had it about 2 months before I bought the alarm, but the starter motor was dead until the same week the alarm was fitted, so not really a basis for comparison)
Yes, this time of year it's all short journeys with headlights on - no heated bits on the bike though!
Removing the alarm would involve rewiring the ignition to remove the immobiliser - doable, but would prefer to avoid.
When we have a half-decent day weather-wise, I'll go over it with a multimeter and give the wiring a quick once-over to check for loose connections etc.
Thanks to all for the pointers
Edit: might be taking the alarm off after all. Discovered today that I'd lost one of the fobs, and I'm not massively taken with the idea of a keyfob with the ability to remotely start my bike floating around in the wild. ____________________ Current Bikes: 1983 Honda VF400FD / 2003 Honda VT750 Shadow
Bike Test Passed 18/03/09, Car Test Passed 14/05/13 |
The last post was made 17 years, 291 days ago. Instead of replying here, would creating a new thread be more useful? |
