lossing speed
plugger147
PostPosted: 02:16 - 02 Jan 2009    Post subject: Reply with quote
Thats the problem, you've changed your gear ratio's by wearing down your tyre so the speedo will be out. Laughing
There could be loads of reasons why, needing a service/weather/binding brakes etc. Do you have any other symptoms?
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
Finglonga
PostPosted: 14:21 - 02 Jan 2009    Post subject: Reply with quote
Weather or binding brakes wont make any difference to gear/speedo ratio at all.
Andy Sez....
F.Y.Y.F.F.
PostPosted: 15:01 - 02 Jan 2009    Post subject: Reply with quote
If you are needing more revs in the same gear for the same speed then that suggests the clutch is slipping, or the tyre is seriously worn / low on pressure (very seriously low....). Clutch slipping could be the clutch plates, could just be badly adjusted, could be contaminated oil (ie, one of the oils that wet clutches do object to, or worse something like Slick 50).
Could also be the speedo is reading incorrectly (or was before and is now more accurate).
This is assuming you haven't put on new sprockets and changed the gearing.
Pie-Roe
PostPosted: 16:30 - 02 Jan 2009    Post subject: Reply with quote
Is your chain loose? I swear I got told a loose can drain power.
Pyro
Al
PostPosted: 16:37 - 02 Jan 2009    Post subject: Reply with quote
Pyro
It can, but it wouldn't cause the revs to be higher at the same speed. Well unless the sprockets are so worn that the chain is actually slipping but I'm sure that would be noticed!
Yamaha FZR400RR 3tj
My Instagram Thingy
owdamer
PostPosted: 17:14 - 02 Jan 2009    Post subject: Re: lossing speed Reply with quote
the warped one wrote:
I'm loosing speed in the rev's range, I used to do 60mph to 4k but know it 4.5k to 60mph, I have a worn tyre but surely this can't be the problem.
Please help.
Warped
Maybe your wearing more clothes coz its winter and the extra wind resistance means you need more revs.
Maybe the cooler air we've had due to the frost has uspet the fuel/air mixture and robbed your engine of power meaning you need more revs?
Maybe your going uphill?
PostPosted: 17:22 - 02 Jan 2009    Post subject: Reply with quote
In any particular gear the revs and the speed speed are directly proportional. The only way for the revs to change at the same speed is if you use a different gear or something in the transmission is slipping (or a very slight change from tyre wear).
Basically doing 4500rpm rather than 4000rpm at the same speed in the same gear means that there is a mechanical problem.
Pie-Roe
PostPosted: 23:04 - 03 Jan 2009    Post subject: Reply with quote
I'm sure this is very simple but I still don't get it, but I'm really not physics or mechanically minded.
Surely if there is more resistance, like if you have a flat tyre or a loose chain, you lose power being put wheel to ground, and therefore you need higher revs per speed?
So for example with a correct tyre, if I'm doing 60mph in 3rd at 5k, if my tyre is worn, or my chain is loose wouldnt it cause the loss of power being transferred from the crank to being put down on the ground. So at 5k there'd be less power going to the ground and therfore you'd be going slower, but the engine would be working the same?
If I'm being completley retarded ignore me Embarassed Laughing
Pyro
PostPosted: 23:18 - 03 Jan 2009    Post subject: Reply with quote
Err, think you are getting confused.
Yes at a constant speed if there is more resistance you need more thrust to overcome this. Normally you get that from using more throttle.
If you need more thrust than the engine can deliver at the revs that equate to the speed you are doing in the gear you are in then you change gear to one that is more appropriate, and then the revs change for the speed you are doing. Eg, 5000rpm in 5th gear might be 85mph, but 5000rpm in 4th gear might be 75mph.
It isn't the load that has changed the ratio of revs to road speed, but the change in the gearing that you are using. Those gear ratios on a normal gearbox cannot change themselves.
To answer your last sentence, yes there would be less power and that would mean (assuming you are on full throttle) the car would not maintain the same speed and would slow down. But the engine revs would also slow down by the same ratio.
plugger147
PostPosted: 23:19 - 03 Jan 2009    Post subject: Reply with quote
If the brakes were binding then you'd have to use more power to get the bike to move however it was that bad you'd probably seen the discs glowing by now.
Pie-Roe
PostPosted: 23:50 - 03 Jan 2009    Post subject: Reply with quote
Kickstart wrote:
Clever stuff
I get it now, I knew gearing isn't dynamic but for some reason I was assuming it was changing along with the resistance and revs.
Pyro
Matthie
PostPosted: 01:06 - 04 Jan 2009    Post subject: Reply with quote
One of the biggest factors I have noticed that changed speed/performance is tyre pressure, made a difference of 10mph on the top end of the FZ and a hell alot of stability. The tyres were dangerously low though, never presume the last owner had them at the right pressures. Rolling Eyes
The last post was made 17 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.56 - MySQL Queries: 13 - Page Size: 84.61 Kb
