Honda SLR ~ FMX ~ Vigor...All the same?
PostPosted: 12:34 - 04 Jan 2009    Post subject: Honda SLR ~ FMX ~ Vigor...All the same? Reply with quote
Are they the same bike with a different body on?
Basically,i'm wanting to put super-moto wheels on it.
Would be ideal if the fmx stuff fits..?
Thanks
Dave
DRZ-400sm
hmmmnz
PostPosted: 14:04 - 04 Jan 2009    Post subject: Reply with quote
only the engine is the same,
different frame, but i dare say a few things will cross over.
the humans are dead
I kick arse for the lord
PostPosted: 17:09 - 04 Jan 2009    Post subject: Reply with quote
Cheers mate,i assumed the frames were the same.
So how does it work with fitting different wheels,do i have to use a front wheel from a similar weight bike? or could i put a 17" front wheel on off a dt125? I know the axle bolt/bearings will be different, i just mean for the overall strength of the smaller wheel.
Thanks
Dave
DRZ-400sm
hmmmnz
PostPosted: 20:23 - 04 Jan 2009    Post subject: Reply with quote
get the wheels you want, say cb500 wheels,
keep the original axles, change the bearings and the internal wheel spacer to suit the axle,
you'll have to sort the caliper to the disc as well and also the spacers and speedo drive to make sure the wheel is centered.
i would stay with honda wheels as you'll have a lot higher chance of getting the bearing diameters the same,
a good thing to do is check online first
go on wemoto and check each bike
eg. the vigor 99-00 uses a 15x35x11 front wheel bearing... 15mm axle. the slr uses 15x35x11 as well the cb500 also has a 15mm axle ect ect.
as for strenth id go for something roughly the same weight,
i'd say the dt125 wheels probably would be more than strong enough,
but.... i don't know, maybe the spokes are shit quality and the wheel will just fold first big bump you hit. Very Happy lol probably not
the humans are dead
PostPosted: 21:49 - 04 Jan 2009    Post subject: Reply with quote
Cheers Thumbs Up
I'll find out about the wheel strength and see how it goes.
Very Happy Thumbs Up
DRZ-400sm
hmmmnz
PostPosted: 22:10 - 04 Jan 2009    Post subject: Reply with quote
i'd say go for the fmx stuff if you can find it, it looks like they all run the same sized axle,
although it also looks like the dt125 runs a 15mm axle as well,
are you wanting spoked wheels or would the solid cb500 wheels be fine??
they would be better if you are saying on the road, if your considering going off road as well
then stick to spoked wheels
the humans are dead
PostPosted: 00:09 - 05 Jan 2009    Post subject: Reply with quote
Yeah i still want spoked wheels.Road wheels just dont look right on traily's IMO
I've seen some ccm604 front ends going fairly cheap on ebay,so might be cheaper and easier to use that.Just have to see what comes up.
I'm gonna have a mess around trying to fit the dtr front wheel just to get an idea of how everything works.It's staying off the road until summer so i have plenty time to mess about with it Very Happy
Dave
DRZ-400sm
PostPosted: 16:13 - 11 Jan 2009    Post subject: Reply with quote
Just curious mate,how do you know the frames are different? Have you seen them yourself or is there some info written somewhere on the net that you used to check?
Normally i wouldn't doubt you,but i've been looking around at different pics and they look identical.
Thanks
Dave
DRZ-400sm
The last post was made 17 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 58.51 Kb
