Reving an older NSR125L...
elk
PostPosted: 15:55 - 07 May 2004    Post subject: Reving an older NSR125L... Reply with quote
Hi guys,
Just wondering: whenever I'm in the mood for a bit of speed and rev my bike fairly hard off of the lights, the Oil warning lamp on the speedometer comes on for the next 10 seconds or so. Is this alright, or I am flogging it too hard / the bike needs some attention. (Hope not: I only bought it recently!!) Also, every so often when I'm stopped up just idling over, the light will sometimes flicker on and off. Same question basically: is this a bad sign of anything, or nothing to worry about at all. Don't actually know anyone else with an NSR at all, so I thought I'd try posting...
Not sure of the precise model of my pic, so I posted a pic in the last thread I started: https://www.bikechatforums.com/viewtopic.php?t=24889
Thanks a bunch! Smile
tom.
McJamweasel
BCF Junkie
PostPosted: 15:59 - 07 May 2004    Post subject: Reply with quote
It means that you are getting low on 2 stroke oil. Fill it up with some good quality semi-synthetic or full sythetic.
If you let the 2 stroke run out the engine will seize.
elk
PostPosted: 16:11 - 07 May 2004    Post subject: Reply with quote
Hmm, I've definitely been keeping my oil topped right up. I'm pretty sure I bought quality stuff as well: Got it from Infinity, called something like Fuchs!?? (Am useless with names!)
Topped it up last night, will see if the same thing is happening over the weekend... Is it possible that the flow of oil to the engine isn't working as well as it should?? Confused
tom.
McJamweasel
BCF Junkie
PostPosted: 16:13 - 07 May 2004    Post subject: Reply with quote
The warning light is connected to a sender unit on the 2 stoke tank itself.
Are you sure that you filled the 2 stroke (tank is under the rear seat on the left) and not the gearbox oil (on the engine)?
elk
PostPosted: 17:08 - 07 May 2004    Post subject: Reply with quote
Yep, definitely the one under the seat!
Wasn't even aware of gearbox oil -- how often does that need topping up!?
PostPosted: 19:20 - 07 May 2004    Post subject: Reply with quote
Sounds most likely that the oil level sensor is failing, so check the oil level manually and regularly. The oil light only refers to the level of 2 stroke oil in the tank, and does not mean anything about oil pressure of flow of oil to the engine.
Fuchs = Silkolene.
The gearbox oil should rarely if ever need topping up on a 2 stroke.
The last post was made 21 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 48.04 Kb
