yamaha r6 dash bulb type?
gray84
PostPosted: 13:55 - 11 Jan 2009    Post subject: yamaha r6 dash bulb type? Reply with quote
hi just wondering if anyone knows what bulb fits into my warning lights on the display ie the indicator,full beam ect and is it just a white bulb with coloured lense.
i dont want to take the bike apart and then gp hunting for parts. i just wanna get the bulbs before hand then attack it.
2002 r6
cheers for any info
gray
robbobnob
PostPosted: 16:00 - 12 Jan 2009    Post subject: Reply with quote
pretty sure its just a small led and coloured lens. i might be getting mixed up with my rs125 though, I'll check tonight.
R6_Rider
PostPosted: 16:45 - 12 Jan 2009    Post subject: Reply with quote
I took mine apart this weekend to check the bulbs as my N isn't lighting, I can confirm that the bulbs are coloured too.
I was surprised to see the coloured bulbs but they are.
Cheers,
Si
R6_Rider
PostPosted: 16:47 - 12 Jan 2009    Post subject: Reply with quote
Oh just to add that the bulbs are soldered into the board so if you were to change the bulb you would have to have a soldering Iron.
I guess it can be done but you would just have to be carefull.
I may be wrong but it looked like they were soldered in place, I did give it a bit of a pull but you can't really get anything in there to pull out. The clock comes apart really easy, there are no loose parts inside so give it ago.
Si
gray84
PostPosted: 21:55 - 12 Jan 2009    Post subject: Reply with quote
ok cheers. i was told they can me removed. my problem is. i have just fitted led front and rear indicators and a small amount of current is being passed to either side when one side is on and the green dash light now doesnt work. iv fitted the relay which has solved the flash speed but its still passing current as it was when they were 1st fitted. also to note i have re wired them twice now so there are no shorts in the circuit.
please please help Confused Confused Confused Confused Confused Confused
There is a gap of 1 year, 145 days between these two posts...
M40TT
PostPosted: 10:45 - 07 Jun 2010    Post subject: Reply with quote
Did you ever manage to fix this problem?
Im having the exact same problem after fitting front & rear LED's, plus the new relay to slow the flash rate down.
Any info would be much appreciated.
Cheers.
woll
PostPosted: 11:00 - 07 Jun 2010    Post subject: Reply with quote
Not sure if the same applies but when i fitted LED indis onto my dtr125 i had to take the bulb out of the dashboard to stop the current being passed onto the opposite side to where you are inidicating. eg. when i turned the left side on the right side lit up slightly. But taking the dash bulb out sorted this.
gray84
PostPosted: 08:31 - 08 Jun 2010    Post subject: Reply with quote
yes mate. i took it to a garage and i used a universal led relay and they fitted a yamaha relay that (not the standard one) it looked the same as the motrax universal relay but said yamaha on it.
worked perfect then mate..
The last post was made 16 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 57.51 Kb
