RVF RECTIFIER???? HELP
 Topic moved: from General Bike Chat to The Workshop by Korn (8 May 2004 - 16:45)
Wezrvf
PostPosted: 17:15 - 07 May 2004    Post subject: RVF RECTIFIER???? HELP Reply with quote
The regulato/ rectifier blown on my RVF so i went out to get a new one but all he had was one off a 125, not sure what kind but it was a honda. It looks totaly different but has the same wires going into it. Will it be ok if i connect this up or will it do more damage that good. Any help will be great as i am useless at stuff like this.
Wez
p.s= The new one is metal and has alol slits through it, better for cooling or something. the guy said it will be fine but i just want to check with the pros, hehe.
Thanks
!! MY OTHER RIDE IS YOUR GIRLFRIEND !!
Phoenix
Twisted Firestarter
PostPosted: 22:42 - 07 May 2004    Post subject: Reply with quote
Well what do you think?
No it won't work because it's unlikely a 125 uses the same charging system as an RVF400. You need an RVF one, which is probably the same as the NC30 and Fireblade 400 and 900, SH633-12 I believe, the numbers stamped on the reg reg.
PostPosted: 22:48 - 07 May 2004    Post subject: Reply with quote
Might work, but not sure. Check that the contacts are exactly as required. Also not sure if the smaller one from a 125 will be up to the higher current requirements.
Personally I would hold out for a proper RVF one, or an aftermarket one for an RVF. It is hardly like Hondas for the past 10 years have had reliable charging systems.
The last post was made 21 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.24 - MySQL Queries: 16 - Page Size: 36.6 Kb
