Am i doing the U-turn right
PeterNSR
PostPosted: 20:54 - 12 Jan 2009    Post subject: Am i doing the U-turn right Reply with quote
Hey Everyone
Not booked my test yet but got very paranoid about it Shocked
Went to a very quiet industrial site and done some practicing Thumbs Up
Am i doing the U-Turn right Confused
Sorry for short video Thumbs Up
https://uk.youtube.com/watch?v=KrH5U3QYUZE
Current: Honda NSR 125 Smile
My bike
Ant132
PostPosted: 21:02 - 12 Jan 2009    Post subject: Reply with quote
What you want is a shoulder check to the left, shoulder check to the right then pull away. Just before you turn in, make a lifesaver over your right shoulder and turn in one smooth action finishing close to the kerb at the opposite point to where you started. Thumbs Up
1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200
PeterNSR
PostPosted: 21:05 - 12 Jan 2009    Post subject: Reply with quote
cheers Ant
Not spoke to you in a while Laughing
is my speed ok
Thumbs Up Mr. Green
My bike
Ant132
PostPosted: 21:11 - 12 Jan 2009    Post subject: Reply with quote
Laughing Thumbs Up
No speed limit as such, i'd just take it as slow as you are comfortable with to show that you are giving awareness to things around you and not just trying to quickly ride it. Obviously not slow enough for your feet to come down Razz Try it on different roads, different surfaces and widths. It's probably one of the easier parts of the test i found, but can be tricky if you haven't quite got it. Find a good combination of the back brake, throttle and clutch and you will master it! Thumbs Up
PeterNSR
PostPosted: 21:14 - 12 Jan 2009    Post subject: Reply with quote
Cheers dude Thumbs Up
Going to go there everyday after work and do about 10-15 minutes worth Mr. Green
My bike
Ant132
PostPosted: 21:16 - 12 Jan 2009    Post subject: Reply with quote
Practice makes perfect! Thumbs Up Smile Thumbs Up
TUG
PostPosted: 01:33 - 13 Jan 2009    Post subject: Reply with quote
I didnt see your rear brake showing as such, but was wondering, do you use your rear brake? Cos when i did my test i used it an since then, thats how i perform a U turn, revs high enough to let you "drag" the rear brake to stabilize yourself at slow speeds.
Haz ER-5, innit!
loply
PostPosted: 18:01 - 16 Jan 2009    Post subject: Reply with quote
Interesting, where did you learn that?
I'm an instructor, there may be variances in technique, but there are a few things wrong with this.
Most importantly, you never do a lifesaver without also checking your mirrors. Its mirrors and lifesaver - one cohesive motion. A lifesaver with no mirror check only gives you part of the story. You'll miss the car that's about to kill you because it's outside your lifesaver field of vision.
Secondly, why do a shoulder check to the left when you're stationary at the curb and about to move away from it? Only check to the right, where relevant things may be. Once before you move, once after a few meters just before you turn in.
Slip the clutch, keep the revs up, keep the transmission under tension at all times. Use back brake if required.
Yamaha SZR660 Caution to the wind, the throttle pinned!
The last post was made 17 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 59.2 Kb
