| LanaTheGreat |
 LanaTheGreat Scooby Slapper
| sumpgard |
 sumpgard Nova Slayer
| LanaTheGreat |
| sumpgard |
| LanaTheGreat |
 Posted: 14:19 - 01 Jan 2009 Post subject: |
I went to Perry Yamaha in Durban, South Africa. The workshop guy took a good look at the gears, and said that they are okay
The nut holding the gear shaft was loose, hence the noise that came from 6th gear, and he showed me the slight damage to the shaft, but said everything was fine. |
| sumpgard |
 Posted: 11:34 - 02 Jan 2009 Post subject: |
Gears can suffer a bit of pitting especially on low-powered bikes like that one and still be ok to use. They will likely last quite some time. The faces of gears don't slide against each other much as many people think - they actually just press against each other and the contact-faces 'roll' together and apart, only siding at the start and the end of meshing. Personally, I'd keep using it until it started making horrible gearbox noises and keep my eye out in the meantime for a spare-parts engine.
https://www.mech.uwa.edu.au/DANotes/gears/meshing/gearAnimation.gif ____________________ a.k.a 'Geri'
| hmmmnz |
 hmmmnz Super Spammer
| LanaTheGreat |
| LanaTheGreat |
 Posted: 13:33 - 02 Jan 2009 Post subject: |
Didn't know they did the DT175 that recently, but just checking the Yamaha South Africa web site it is a current model. Still appears to be using the old air cooled engine (bore and stroke are the same as the late 1970s ones).
I would say there is a fair chance the pistons are interchangeable.
Wiseco pistons are generally very high quality forged items. Probably rather better quality than the stock Yamaha ones.
For something cheaper a quick google found these people more local to you, with over size pistons up to 2mm oversize:-
https://www.imoto.co.za/pistons.htm
| LanaTheGreat |
 Posted: 22:47 - 05 Jan 2009 Post subject: |
Keith, thanks a lot for that. I dropped them an email and they said a piston kit will cost ZAR290.00, that is equivalent to US$32.00, a fair price indeed.
I quote the guy's reply: "The sleeve can be rebored, 66,5mm is first oversize (0,5mm), so you still have three rebores left there. The cost for the piston kit is R290-00 plus R50-00 for overnight to your nearest Post office. I must just check to see what sizes are available."
Funny he says that the 66.5mm is first oversize, as according to Yamaha, it is top oversize. I am not complaining. Do you think that this will be a good option to go for, and will the piston be of an acceptable standard?
I went to several engineering places today, there are loads of them in my area, yet none could help me with reboring the 2 stroke cylinder. I will keep looking... |
| LanaTheGreat |
 Posted: 23:26 - 13 Jan 2009 Post subject: |
Would expect a full pattern gasket set to be fairly cheap.
You might get away with reusing the clutch cover gasket, but I wouldn't be certain. On the other hand it should be easy to do at a later date if it leaks. But it only takes one leaking gasket for you to have to strip down the engine again and have to replace the gaskets you did buy new.
| LanaTheGreat |
| LanaTheGreat |
 Posted: 19:54 - 19 Jan 2009 Post subject: |
I received the Emgo piston kit this morning (piston, gudgeon pin, circlips and rings). I purchased the small end bearing as well just to be safe. Also ordered the clutch side crankcase cover gasket, and the reed valve gasket.
I handed the piston to the engineer as he wanted it before he would re bore, and it should be done tomorrow.
The bike shop owner told me I just have to make sure that the port edges in the cylinder are not sharp as it can catch the rings. Will check that too when it is done.
Will get the wife to start cleaning the engine parts in preparation for re-assembly.  |
| LanaTheGreat |
 Posted: 22:39 - 20 Jan 2009 Post subject: |
| chillpill |
 chillpill World Chat Champion
 Posted: 15:25 - 21 Jan 2009 Post subject: |
sorry to spam but how would you go about finding out if a different piston would fit ?
obviously theres the actuall size of the piston and the gudgeon pin size . but what else do you need to look out for ? i know 2 stroke pistons have ports in them would it be possible to cut ports into a piston ?
cheers  |
 Posted: 15:33 - 21 Jan 2009 Post subject: |
Points you mentioned, plus the offset of the gudgeon pin from the centre, height of the piston (above and below the gudgeon pin), type of ring, number of rings, possibly where the ring end gaps are (you might want to avoid these going over ports), weight, material, manufacturing method and cutouts for ports (which not all 2 strokes will have). There are loads of factors but many of them are unlikely to be an issue (ie, the offset the of the gudgeon pin is not likely to vary much), or are chosen for slightly different uses (eg, forged pistons).
Also things like the shape of the piston crown, although this is more of an issue with 4 strokes which have cutouts for the valves.
The last post was made 17 years, 242 days ago. Instead of replying here, would creating a new thread be more useful? |
