Scratch Question??
david240968
PostPosted: 23:08 - 13 Jan 2009    Post subject: Scratch Question?? Reply with quote
bought a new bike recently and its in a1 condition except for a scratch on the nosecone (it was reflected in the price). do you think it will polish out with tcut or something like that. any advice as to what i should use?
https://i129.photobucket.com/albums/p230/david240968/CIMG3875.jpg
cheers Thumbs Up
m0l0t0v
PostPosted: 23:18 - 13 Jan 2009    Post subject: Reply with quote
T-cut won't fully get it out but it will make it more visually attractive.
I've never had to deal with scratches like that on the Hornet so I haven't tried...
Ichy
PostPosted: 23:25 - 13 Jan 2009    Post subject: Reply with quote
I'm assuming you don't want to do it properly and get it resprayed.
There are plenty of scratch repair pastes on the market such as FARECLA SCRATCH REMOVER PASTE that may give relatively decent results. You will generally still see the damage as a mark but it should be the right colour.
I'm being delibrately vague simply because they are not perfect and may cause more damage if your not careful.
david240968
PostPosted: 23:27 - 13 Jan 2009    Post subject: Reply with quote
if the scratch removers wont work then i will get it done properly. just that i have heard there are products for scratch removal but never used them.
tutton
You wont be able to cut that out with tcut or g3.
can see from the pic it looks deep, unless you flat it and flat it, to get it flat then polish up, but the likelyhood of wiping the clear off and being on the basecoat then is highly likely, which still might be shit and may need stopper and repaint.
Ichy
PostPosted: 23:33 - 13 Jan 2009    Post subject: Reply with quote
I've used pastes loads of times with 'acceptable' results. Personally I find hob cleaner to be more effective but I never advise anyone to try it. Laughing
MattEMulsion
PostPosted: 07:50 - 14 Jan 2009    Post subject: Reply with quote
I'm guessing its an R6. In which case if you were to buy another R6 sticker from a Yamaha dealer, like the one on the other side of the nose cone then you could stick it over the top of the scratch and you won't hardly see it. Then take the R6 sticker off the other side and only an eagle eyed bike spotter would notice that the R6 sticker is on the wrong side and slightly out of position. Its probably the easiest and cheapest solution in my opinion. Thumbs Up
https://i2.photobucket.com/albums/y29/mattemulsion/R6NoseCone.jpg
Yamaha YZF-R6
owdamer
PostPosted: 16:38 - 14 Jan 2009    Post subject: Reply with quote
You need a gel coated number board panel.
The one in the pic is a cbr, but they do other models.
https://www.the-image-works.co.uk/
https://www.bike-stickers.com/images/bikes/protectors/cbr600%2002-04%20gel.jpg
craigs23
Mr Muscle
PostPosted: 19:42 - 14 Jan 2009    Post subject: Reply with quote
And it'll leave a hideous cloud of swirls over the surrounding bodywork.
I'll whip off the nose cone and take it to a professional. Spraying/repairing segments of bodywork isn't that expensive.
PostPosted: 10:21 - 15 Jan 2009    Post subject: Reply with quote
Blue felt tip!
In all seriousness that's not coming out with T-cut, it's gone right the way through all the paint.
tafflade
PostPosted: 10:27 - 15 Jan 2009    Post subject: Reply with quote
I cant see the picture on this computer but from what others are saying it probably need s respraying.
we used chips away (google it for your local one) they come to you and would probably charge you about £60 to sort it.
wifey damaged someone elses car a few months ago parking, we used them to sort out the damage and the people who own the car are dead chuffed with the work he did.
lonner
PostPosted: 11:00 - 15 Jan 2009    Post subject: Reply with quote
with tafflade on this try dent devils auto pallet chips away or any franchised scratch-dent repair as its a clear over base colour and you will probably go through the lacquer and spoil the finish Thumbs Up
giarc
PostPosted: 11:50 - 15 Jan 2009    Post subject: Reply with quote
The general rule I go by, is that if you can feel the scratch with the nail of a finger then it's too deep to remove by polishing. If not, then you may be able to polish it out with the help of somebody with a rotary or machine polisher of sorts.
The Tot
PostPosted: 13:31 - 15 Jan 2009    Post subject: Reply with quote
I've tried to use Tcut on my panels and autoglym resin polish on a similar looking scratch on my rear when the bike dropped in the garden (gravel drive)... I've got the bike booked in to get a vinyl rear numberboard redone - it costs £40-45 to get it done and it's cheaper than a respray - and a lot quicker too. I'll let you know how it looks.
Never argue with autism
The last post was made 17 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.77 - MySQL Queries: 13 - Page Size: 82.36 Kb
