600RR7 - FI Warning
robbieguy2003
PostPosted: 17:35 - 13 Jan 2009    Post subject: 600RR7 - FI Warning Reply with quote
Hi All,
Not the best mechanic/bike mechanic by any means however got a small problem and after a bit of advice.
Was cleaning the bike today and went to turn it on to make sure it starts normally etc and move it so I could give it a rinse.
On the dash there is an 'FI' light for the fuel injection, this normally just comes on then goes off once its done it checks. Instead however it flashed 3 times for about a second followed by 5 short flashes. I thought that might be a diag code so noted it, also, I noticed the amount of smoke coming out of the exhaust was much more than usual however it automatically started to reduce via the automatic choke, the engine sounded and normal.
After looking in the service manual, the diag code refers back to an EGCV (Exhaust Gas Control Valve). This seems to be a little motor under the exhaust (can see it and connections all look clean and ok) that operates a valve in the exhaust itself limiting how much gas can come out at once.
It looks like the motor/servo has died (I bought the bike from new in September 07) so could be a Honda job however main question is do you think it'd be ok to ride short distances with this/do you think it'll affect the operation of the bike.
Its still running a stock exhaust and as I understand it, when you replace the exhaust on this bike, you need a computer chip that replaces this motor and just feeds info back to the ECU to keep it happy, just wondering how critical it is to the operation of the bike. Would this affect back pressure (again, not entirely sure) or cause other issues?
Any advice/comments appreciated, ideally wanted to use it for work this week but wont if its a major issue.
Regards
Rob
Current Bikes: Honda CBR 600RR - '07, Suzuki GSX1250 FA ST '11
Old Bikes: Suzuki Intruder 125 LC - '2001, Honda CBR 600F - '92, Honda CBR 600RR - '03
lonner
PostPosted: 18:26 - 13 Jan 2009    Post subject: Reply with quote
probably just water in the exhaust it may sort itself out but fine to ride to the dealers
robbieguy2003
PostPosted: 18:59 - 13 Jan 2009    Post subject: Reply with quote
Could be, as i've not been on it for a bit - however of all the time I've had it, its had worse nights in the rain and started with no FI issues which has worried me a little.
Cheers for the advise, prob worth getting it to the Honda shop, luckily its only about 3 miles from me at most Thumbs Up
01dabreoo
PostPosted: 16:02 - 14 Jan 2009    Post subject: Reply with quote
Could the valve have sized? I know this is a pretty common problem if the engine light appears on the 675.
Maybe get some penetrating oil on it(where the valve exits the exhaust to connect up to motor)?
PostPosted: 16:10 - 14 Jan 2009    Post subject: Reply with quote
It won't hurt the bike to ride it with a seized valve/broken servo no. It may feel less powerful, but that's it.
robbieguy2003
PostPosted: 21:10 - 14 Jan 2009    Post subject: Reply with quote
Certainly possible, I've not had a proper chance to dig around yet. More than likely be the weekend now before I get to have a proper look. I'll give that a go though Thumbs Up
Less powerful shouldn't be an issue in this weather, good to know it's not going to cause damage riding it though - although, courtesy of work might not have a chance for a bit as I'm getting sent to Denmark next week...
Noxious89123
PostPosted: 22:17 - 14 Jan 2009    Post subject: Reply with quote
Was reading an article in Bike today, that was saying about buying a second hand 954. One of the things it mentions is the servo operated Exhaust valve. It says that the cable that operates them is very prone to corrosion, and eventually it can jam the servo motor. So might want to take a look see if it's rusted to buggery. Might be able to just clean it up.
LeeR
PostPosted: 12:51 - 15 Jan 2009    Post subject: Reply with quote
Funnily enough I had this problem happen on my car, the valve mechanism had jammed open and someone had stuck a piece of tin across the opening so there was no power loss. I stuck a new piece of tin across and ordered a replacement part, it's fine now.
The principle behind this valve is to allow exhaust gases to be re-burnt leading to theoretically cleaner emissions. The valve is set to open at an rpm limit (3k on the car) where this will have little or no effect on power (though of course it has some).
So if it is jammed open and you can't fix it, put a piece of tin plate across the opening and order a new one, mine was £100 from FIAT yours maybe cheaper.
My claim to fame: Austin Vince nicked my pen...
robbieguy2003
PostPosted: 13:03 - 15 Jan 2009    Post subject: Reply with quote
Ah right, just had another quick look today and there is a completely sealed unit under with a cable coming out - but completely plastic coated so hard to see if its rusted inside.
I'll try and have a proper nose around it on Saturday and see if I get anywhere, otherwise I'll take it to Honda.
It does have some of its 2yr warranty left but I'm sure they will use a get out of jail free card anyway.
PostPosted: 16:02 - 15 Jan 2009    Post subject: Reply with quote
To be fair if it is the exhaust valve when you turn the ignition on you'll here and few whirrs and clicks.
If you flick the ignition on and look at the cables you should see it move as the ECU checks the valve. If it doesn't move it's gone.
robbieguy2003
PostPosted: 16:11 - 15 Jan 2009    Post subject: Reply with quote
You could be right, I normally hear several noises when i turn the electrics on and one is missing - so likely to be that.
Quote Me Happy
PostPosted: 16:20 - 15 Jan 2009    Post subject: Reply with quote
Find the servo thing that operates the cable and check it moves on startup. On my kwak it was under the seat and it moved back and forth when I flicked the ignition on.
I had the FI light come on after the fix (to stop the FI light coming on) sent with the aftermarket can came loose.
robbieguy2003
PostPosted: 17:42 - 15 Jan 2009    Post subject: Reply with quote
I fitted an Akra to my RR7, which got rid of that valve, and ran it without the o2 terminator for a while and it was fine. The o2 terminator is the little special doobrie that tells the ECU the valve is no longer there.
Cool, I'm thinking of swapping the exhaust for something louder, I was going to wait till march/april but as this has happened might just get it done now if its going to cost to fix.
robbieguy2003
PostPosted: 18:49 - 15 Jan 2009    Post subject: Reply with quote
You'll need a Power Commander then, but be aware the o2 terminator does NOT come with it, it's a separate order (mine was £15). I didn't find that out until I'd received the PC, and considering the o2 was included in the PC install instructions I thought it a bit cheap of them not to have included the actual bloody part in the kit.
Yeah, will be investing in a PC3. Its annoying that it doesn't come with it, especially for the difference in cost - must be a common problem with people ordering, cheers for the heads up Thumbs Up
I'll be getting a K&N air filter also then prob get some dyno time if possible - the back tyre needs replacing soon so might be the time to do it.
PostPosted: 08:45 - 16 Jan 2009    Post subject: Reply with quote
Maybe it's to reduce emissions on cars, but it's more there to help boost midrange on a bike and for the noise tests.
Hence the EXUP valves on Yamaha's before the days of strict emissions testing.
lonner
PostPosted: 13:27 - 16 Jan 2009    Post subject: Reply with quote
think leer is confusing this with pair valves in the exhaust ports (they help clean exhaust gasses and were brought in by the manufactures to get round the ever increasing emissions laws)
i normally block mine off which usually makes the bike run a lot smoother.
this exhaust valve is purely for low down power and noise laws
PostPosted: 15:23 - 16 Jan 2009    Post subject: Reply with quote
Aa fair. All the PAIR does is introduce a fresh air bleed into the exhaust port and dilutes the nasties with some fresh air and so fooling the emissions reader. Thumbs Up
robbieguy2003
PostPosted: 10:25 - 26 Jan 2009    Post subject: Reply with quote
Just spoken to Honda (Or Andy at Gedges in my case).. Taking it up Friday to get it looked at so hopefully will get it sorted.
Its apparantly running in Limp mode at the moment because the ECU has an error code, needs a service as well so hopefully everything will be running nicely when I get it back.
robbieguy2003
PostPosted: 16:51 - 26 Jan 2009    Post subject: Reply with quote
Tell Andy the chap who bought the RR7 Repsol says "Hi". He's a top bloke is Andy. Thumbs Up
Yeah Andy has been sorted with me, done me pretty good deals on both of mine. Got my RR3 and RR7 from him.
I'll tell him you said hi Thumbs Up
The last post was made 17 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.86 - MySQL Queries: 13 - Page Size: 107.68 Kb
