| MarJay |
 MarJay But it's British!
| Fadel |
 Fadel Trackday Trickster
| Blau Zedong |
 Blau Zedong Banned
| MarJay |
| Blau Zedong |
 Blau Zedong Banned
| MarJay |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
 Posted: 18:12 - 15 Jan 2009 Post subject: |
Hi, i have a friend who's a RD junkie, he recommends a run in period of 600 miles. Don't enter the powerband if you can help it, use your gears so no over labouring up hills etc
He said its a pig of a job but its far far worse having to do a rebore which he says 1000 miles !
Pat ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| Blue_SV650S |
 Blue_SV650S World Chat Champion
| MarJay |
| Blue_SV650S |
| Blau Zedong |
 Blau Zedong Banned
| MarJay |
| stevo as b4 |
| MarJay |
| Blau Zedong |
 Blau Zedong Banned
| MarJay |
| Robby |
 Robby Dirty Old Man
| MarJay |
 Posted: 13:42 - 16 Jan 2009 Post subject: |
Well I've ordered a re-usable copper head gasket from the states. Its slightly thinner than a stocker, and with the head skim should give me the right squish gap. Apparently I've got to anneal it before I fit it, which should be great fun too.
I've also bought some 83mm centre to centre front brake calipers that will fit on the bike as the standard RD 2 potters are crap. They might be a little bit of overkill though as they are 4 pot Nissins from a TT600... not bad for £30 though. There is a guy on the RD forum with them on his bike and they work... quite well shall we say?
As well as the engine rebuild, I also need to drain, clean and seal the fuel tank, remove the wheels and possibly get them powder coated, get new tyres, re fit the wheels, rebuild the front brake master cylinder, fit the calipers and then it should be vaguely ready for an MOT once its all back together. I might also have to find some suitable fork gaiters, because the brand new fork seals are weeping a bit ( I fitted new top and bottom bushes too so I think the fork leg might be pitted or something).
Then I can concentrate on the rear end and seeing if I need stuff like suspension bushes and possibly a new rear shock. I might need to buy a grease gun so I can make use of my grease nipple!
As I said, I'm taking photos as I go and am going to do a big write up at the end I think. I can't be bothered to keep updating an old thread. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| Blau Zedong |
 Blau Zedong Banned
| Blue_SV650S |
 Posted: 14:12 - 16 Jan 2009 Post subject: |
| MarJay |
 Posted: 15:37 - 16 Jan 2009 Post subject: |
Currently the squish is 1.9mm. I'm aiming for 0.9mm - and it won't increase the compression too much. 0.8mm is the smallest you can go on standard octane fuel. 0.75mm is the smallest squish gap you can run. So I should be well within tolerances.
| John Penfold on 'The Elsie Cult' wrote: | Reducing the squish gap also reduces the compressed volume, which increases compression. This actually optimises the compression ratio for the stock YPVS because Yamaha have left a good bit of slack here, too. There are two types of cylinder head on the YPVS models, marked Y1 and Y2. They are clearly marked on the top. The Y2 is the higher-compression head. With a squish gap of 1.9 mm even the 'high compression' Y2 head gives a lowly compression ratio of 6.0:1 (measured from the top of the exhaust port). With a squish gap of 0.9mm the compression ratio rises to 7.1:1, which is actually a pretty good ratio for road use with ordinary petrol. As a rule of thumb, you can push the compression ratio to perhaps 7.7:1 on this engine with ordinary petrol, and retarded ignition, before detonation happens. However, 7.7:1 is not a hard and fast rule, and 7.5:1 is probably a better safe maximum.
The increase in compression can get a bit hairy when the engine has been overbored, which increases the compression ratio. For instance, with a 1 mm overbore and taking the squish gap right down to 0.75 mm, the compression ratio will rise to 7.5:1, which some would consider to be right on the limit for use with normal petrol. If you fall into this area, you might want to consider raising the exhaust port to 26mm from the stock 27.5 mm purely to lower the compression, rather than for other performance considerations. That would lower the compression from 7.5:1 to 7.2:1 in the above examnple, back into the safe area. |
Info here:https://homepage.eircom.net/~johnpenfold/elsie/worksheet1.html ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| MarJay |
| Blue_SV650S |
| MarJay |
| Blue_SV650S |
The last post was made 17 years, 90 days ago. Instead of replying here, would creating a new thread be more useful? |
